Crossmember Spacer Question
+2
gdopnt
jpkinerk
6 posters
So this is embarassing, but what are the four square 1/2 inch spacers for that come with the kit? Won't I just need the two 1/2 inch rectangular spacers for the crossmember?
jpkinerk- Posts : 174
Re: Crossmember Spacer Question
The 4 are used for the cross member and the two rectangle are used for the rear of the A - arms.
gdopnt- Posts : 127
Yep....what he said. There are no such things as dumb questions when doing these builds
the951racer- Posts : 135
like on that hehe.the951racer wrote:Yep....what he said. There are no such things as dumb questions when doing these builds
GudmundurGeir- Posts : 45
I didn't use spacers and it didn't clear the hood. So we made an air vent where the throttle body comes up.
zeusrotty- Posts : 444
How much are you usually ,,dropping" the crossmember ?
where do u get mod'ed Steering shafts ? or u get urs moded ?
matt889- Posts : 214
I had plates welded to the cross member and the control arm bolt holes line bored 1/2 higher. The four cross member plates were used but the two rectangle plates were not used. The original steering shaft is cut and a spacer is used welded and pined.
the (x) - my spacers are 1/2. A math mathematician work it different. I didn't do that and added (x =1/2) I drive mine when ever no popping , no binding. all this is information for you to use for your own application. some people lower 3/4 so this diagram is for that drop.
The u-joints must have the same clocking so if you look to the left of Allen head a scribed line is on the shaft before cutting to match one on the extension.
I had the maker of the shaft cut out slots for more welding area this is not in diagram.
watch out for this when you get there you will need to turn around the engine mounting bolt as to not hit the u joint on steering shaft.
gdopnt- Posts : 127
