Header Spacer Option
I know that in one of the header threads someone suggested using a header flange bolted between the head and exhaust manifold to allow clearance for the steering shaft. I have been giving this some thought for use with the stock manifolds. Does anyone know how much space is available to space the stock manifold out? I found a set of 1/2" spacers. if there is more room than that, I could have something made at work.
I wonder if this really would work??
Last edited by Bluemach1 on Sun Mar 14, 2010 10:59 am; edited 1 time in total (Reason for editing : wording)
Re: Header Spacer Option
Nobody? Sounds like a very easy fix for headers..
HandofTron- Posts : 22
wouldnt know myself. I ran the RH headers, but I guess it would all depend on the length of the runner coming form the exhaust before bending down.
I know with the RH header the exhaust is rubbing the frame and I had to hammer alittle to get a clearance.
I couldn't tell you either, but once you have the motor installed and you're ready for a header, why not just put 1" of washers in two holes so you can mock up the fit? That's the easiest way to tell for sure.
Yes, that is what I'll have to do. But I was hopeing that someone might be at that point now. It would be great to have this sorted out when I drop mine in. Trouble is that I think I might be the only guy on the board considering the stock exhaust manifolds thanks to the California smog nazis.
If anyone is in a position to give this a look that would be very cool.
