New member considering LS1 swap.
+4
RS Technic
LS86NA
8 posters
Hi there guys, my name is Roman and I own, maintain and daily drive a 1986 Porsche 944 N/A. I have been considering an LSX swap for a long time and I believe I have enough money saved up to do the swap. What I'm concerned with is the difficulty of the swap. I have built engines, swapped a few (same manufacturer) and have confidence I can bolt things together .
I also have a 87 trans am that I know would be much easier to swap than my 944, but I love the 944 chassis and build quality so I would like to go through with it if I am capable. Is there anybody in Washington state with an LS swap I could talk to or possibly see their car? I just have so many questions! And yes I know how to use the search button haha. Thank you all for taking the time to read this. Happy new year.
LS86NA- Posts : 5
Re: New member considering LS1 swap.
Welcome. I would think that if you have built engines as well as done a few "swaps", you'd be good to go on the LS conversion. It's not really that difficult and there is a wealth of info available. Good luck.
Swap
I agree with Lemming.
The swap itself is not difficult, it more time consuming.
I personally have found the most difficult part has been the "...as long as I'm in here/have it apart" syndrome.
My project went from a swap to a down to the frame rebuild.
When I'm done it will be a new car, but it has added a considerable amount of time.
Even so, I'd start it and do it again in a second.
RS Technic- Posts : 73
Swap
Welcome, you will not be disappointed. Mine went the same one thing after another but well worth the time and effort. Good luck and enjoy the process.
kevin924kevin- Posts : 927
Just as an aside, whatever you think your budget is, double it.
You will NEVER regret the swap!!!! I believe I may have been the first swap in the country ( at least using the Renegade Kit, so I had to get a lot of help from Renegade and the LT swappers here. It is not difficult. per se, and if you have built engines, you will be fine. I started mine in early September and drove the car at Christmas. am sure others here have done it both more quickly and a more slowly. While building mine, I got a ride in Predators LT1 conversion and it really lit a fire under me to get mine done, so if you can get a ride, I highly encourage it. It is a completely different car with the v8. The guys here are great and help you a lot.
Thank you all for the input!.
The "while you're in there" syndrome is a real thing for sure, however I'm going to try to keep it at a minimum this time. The main thing I'm concerned with is the braking system, clutch disengagement (sp?) and the torque tube alignment. The main thing is I don't have access to a welder and my fabrication skills are limited. Is there a truly "bolt in" solution to the ls swap? I'm planning to run no A/C and I would like to run manual steering depending on how much parking lot steering effort changes - I'm planning on keeping this car my daily driver after the swap. I wish there was someone close to me that would be kind enough to take me for a ride, but I haven't even seen one in person yet.
Thanks again
Thanks again
LS86NA- Posts : 5
For me, it was as "Plug n Play" as you get, granted as long as you get the correct engine and accessories from the get-go. The kit i got from TPC made it easy, to be honest. Budget timing was my issue on how quick my build has gone. Plus, "just doing the swap" has turned into "ok, i need better brakes" to "ok, now i need springs and torsion bars" and so on. All depends how deep you want to go, and i suppose the condition of the car currently would have a bit to do with what you would replace or not. To me it seems each 944 swap ive seen (interwebz) has its own particular quirk to it in terms of how the engine sits in the bay, and some wiring(maybe more, im still on my first one ).
If you're mechanically inclined type person, and do well with things like that: I say have at it. PLENTY of help here on the forum!
If i had the choice again to do it, or not do it. I would DEFINITELY do it. and if you do: BEST OF LUCK!
w00tPaPa- Posts : 14
I think I'm going to go ahead and do it, sounds like I should be able to get this swap done. I have a budget of about 15k to get this done, I'm hoping that will be enough. Time to start looking for an engine. Is the F body LS1 what I want?
LS86NA- Posts : 5
Correct:F-body LS. Preferably 1999+ for ECU tuning AND (as i found out) the older LS's (like mine aka: "perimeter bolt") have much taller valve covers, and with the hydroboost, the DR side MUST be cut down for MasterCylinder clearance. If you are running power steering i suggest poking around a bit with the advanced search, i cant speak much on it as i have a manual rack, and am not entirely sure of the differences other than my p/s pump only runs the brakes. Spring for the longtube conversion headers.
Very good to know, thank you.. I was planning on running a manual rack and brakes. What size tires do you run? I'm worried about steering effort.
LS86NA- Posts : 5
Hi Roman. I'm in Seattle and would be happy to show you my car. I'm in the midst of a move across town, fixing up a house but the car's still at the old place. Mine's a track car, interior gutted w/ cage but it is registered and insured for street use. In fact, it's overdue for a romp about town.
I did the swap myself having done only one engine swap like-for-like make before. I don't weld but have a buddy that helped me with that. I used a scissor lift which was instrumental. Initially I did manual steering and brakes but recently added power steering as the ratio was too slow and the effort too high with 255 track tires. (Other's disagree...) And as Lemming said, I blew my original budget quite badly.
Shoot me a PM and we can setup a time to meet-up.
Hi Roman,
Welcome. I'm in the middle of my swap and it's definitely the biggest project I've taken on, but definitely feels do-able. Previously I had done a few like for like engine swaps and prepped a couple race cars. The work itself isn't that difficult; but it's complex. I think the biggest issue is that it's not really plug and play because there so many variables and so many "right" ways to get things done depending on your goals and preferences. So be prepared to do lots of research on various options, look at what others have done and then decide what's best for you. I don't have a lot of fabrication or welding skills and so I tend to rely on purchasing known solutions rather than building from scratch, which is a bit more limiting and a bit more $. Your skill set may be different. Good luck on your project! The advanced search is your friend and the folks here will pretty much always have answers for your questions.
majormojo- Posts : 82
Rich,
I would love to see your car and pick your brain about the swap. Seems my post count is too low to send PMs?
Majormojo,
Thank you for the insight. The complexity is what scares me the most about the swap, though I have always been one to go above and beyond to do things the "right" way. Hopefully this swap is right up my alley.
Thank you everybody for the replies. It seems this forum is a place full of friendly people! I'm looking forward to being a part of this community. Good stuff.
Majormojo,
LS86NA- Posts : 5
Looks like you're at 5 posts now. You should be good to PM.
