New member Starting lq9 944s swap
+3
wingdog
lq944
7 posters
Hello, all. I am new to this site but have been active on ls1tech for a while now. I'd like to introduce my project and I will probably post my progress as I can. I just picked up an '87 944s with intentions of swapping my lq9. The lq9 has a 228r cam, dual valve springs, arp head and rod bolts, double roller chain, high volume oil pump, new ls7 lifters, ls9 head gaskets, etc. The car is a 1987 944s painted Lamborghini pearl yellow. It has the German rear bumper and the turbo front. No rust. I will most likely be purchasing the TPC swap kit (not sure which one yet), and fabricating some parts as well. If there's anything that I should look out for that gave you guys problems during this swap, let me know. I'm have a pretty good idea of what this swap entails but am still in the process of researching (you can never research enough).
Anyway, here are some pics of the car and engine:
lq944- Posts : 17
Re: New member Starting lq9 944s swap
Good luck with your project. I haven't posted much but been lurking quietly while working on putting an LM7 in my 83. I'm almost ready to fire it up and its killing me sitting there and not being driven. I too got lots of good info from LS1Tech and my wiring info from LT1swap.com.
wingdog- Posts : 15
Thanks man!
Update: I ended up buying the deluxe tpc kit today.
lq944- Posts : 17
Love the color! Good luck.
Millennium Yellow - I know it well
skywalker01- Posts : 477
Just got the motor in today. Looking like it belongs in there!
lq944- Posts : 17
Looking Great!
Now, that's the way to do a V8 conversion. From the ground up!
What are you doing for brakes, transmission and clutch?
Thanks and keep posting updates!
mc05duck- Posts : 13
RE: LQ9
Hey looking good. Question because your using a truck engine did you need a crank spacer and if so what did you do about the starter and bell housing spacer???
jrod63chevy- Posts : 18
Its an "s" so all brakes and suspension and trans are staying stock for now. The truck engine does not require any crank spacers.
lq944- Posts : 17
"oh wtf"
Well that was a waste of 70$ lol never listening to outsiders again haha. Thank you
Only the "early" lq4 with iron heads require a spacer
lq944- Posts : 17
Just a couple updates/teasers
lq944- Posts : 17
Following!! Nice color
matt889- Posts : 214
Today at 12:47 am by sharkey
