Today at 12:30 pm by sharkey
Today at 8:54 am by Rich L.
Yesterday at 5:04 pm by AMFCSL
» Transaxle rebuild
» Hello, Gentlemen.
» alignment specs
New Member
New Member
Post  cjbcpa on Thu Jun 24, 2010 9:25 am
Hello to all,
I'm a current 951 owner that will probably perform an LSx conversion in the next year or so. I use my car primarily for DE and recently threw a connecting rod, destroying a pretty juiced up turbo motor. Fortunately, I have a spare running stock motor that I will drop in to get back on the track.
After looking things over, it seems the 944 conversion has evolved nearly to the point where its as close to plug and play as you can get. Makes me really excited to give it a try. Will make a nice winter project between track seasons.
Regards,
CB
cjbcpa
Re: New Member
Post  948 on Thu Jun 24, 2010 11:22 am
Welcome.
I see that you are in the Philly area, ~1 hour from me.
Re: New Member
Post  xschop on Thu Jun 24, 2010 11:42 am
welcome to the madness....
Re: New Member
Post  stuart f. wright on Thu Jun 24, 2010 12:21 pm
welcome to the forum .you will like the v8 much better
stuart f. wright
Re: New Member
Post  cjbcpa on Fri Jun 25, 2010 8:18 am
I'm actually north of Philly, close to Quakertown. Close enough to meet sometime and discuss the conversion process?
Chris
Welcome.
cjbcpa
Re: New Member
Post  Vorsche944 on Fri Jun 25, 2010 9:33 am
Welcome and going LS1 to a Turbo is sweet. I have the 87 with a 2000 LS1. I will be in Hershey tin July if you wanted to get together and talk. PM if you want to get together.
Vorsche944
Re: New Member
Post  948 on Fri Jun 25, 2010 11:46 am
You've got a PM
Re: New Member
