Sparkydog's Abnormal Build - 944 With L67 + Ford Stuff & CARB Legal
+8
Hotrodz of Dallas
jimlam56
v2rocket
racertomtom
haroldk
sparkydog
12 posters
Page 4 of 4
Page 4 of 4 • 1, 2, 3, 4
Re: Sparkydog's Abnormal Build - 944 With L67 + Ford Stuff & CARB Legal
Hey guys I could use some help again. I want to re-create the Porsche throttle pedal ergonomics but I hacked out the factory firewall and throttle cable brackets. Can anyone hold some paper or cardboard along the side of their gas pedal and trace what angle it has from the floor at both idle and full throttle? I'm still using the stock pedal and where it mounts to the floor but don't know where in space to position the angle or how much it travels.
sparkydog- Posts : 96
Wire harness/loom out of an 00's Buick Lesabre - which is a domestic, modern GM car with rear seat mount battery. I feel like I'm getting a relatively clean and integrated set of power dist technology plus a big chunk of body harness all in one package.
Starting to play with radiator and fan options. I found what most of you guys are running on the V8 conversions but decided to try an OEM factory solution first. Some of the photos show a Jeep radiator but I have ruled that out. I am currently designing brackets around a Ford Ranger/Explorer 4.X L radiator married up to the donor Mustang's V6 fan.
Over the past several months I have been fabbing various brackets that mount the radiator, cooling fan, horns, washer fluid bottle, ps cooler, ps fluid tank and other items.
Then primer on them.
Sealer.
And final color.
Sealer.
And final color.
And I have pulled the motor out one last time - to finish working on the engine bay. Then I will paint the bay and put the motor in - with a goal of trying to get it making noise by around July of this year.
The engine bay is ready for an engine.
Motor is back in the car.
Looks great! Are you driving it yet?
Sirayden- Posts : 37
Not even close to ready to drive!
I’m deep into wiring right now. Mashing harnesses from at least three different cars.
I know the feeling. Feels like my car is going to fossilize before I get it on the road again. Headers and twin turbo plumbing are holding me up. Haven't started wiring yet but have a 99 GTP harness. I hear the Monte Carlo harness is easier.
Wiring porn.
3 donor harnesses that I snip colored wires off of.
You'll get all of that sorted out. It's cool how you have that custom engine bay.
No muffler yet and probably a couple of exhaust leaks. However progress is progress!
I shot a better resolution vid of the motor running and updated the post above.
I've purchased a Ford 8.8 posi rear axle with factory 3 link and am starting to convert my 944 over to this axle. I'll be swapping the rear discs over and there will a few months of fab work ahead as I delete the mounting points for the upper 4 link and convert to a 3 link and panhard bar.
And I have the start of my exhaust system:
Wow almost a year without updates! Bad Sparkydog, bad!
OK the exhaust parts were converted into this:
And the 8.8 posi 3-link conversion from the 7.5 4-link is finished:
With panhard bar:
To accomplish all that I had to rewind clear back to this:
Also note a wider driveline tunnel in that last picture. That's because my GM motor is offset to the right about 2" and the Ford 8.8 rear axle is asymmetric as well.
With panhard bar:
A couple of shots of the 3rd link and it's mounting bracket:
Panhard bar diagonal brace:
I'm still working on the floor area behind the drivers seat.
I created my version of a poor man's car scale system. I bought a $30 digital bath scale that had a 500# rated capacity and then spent another $30 on lumber to make up the stuff in the photos. Basically it's a spreader board/beam that divides the corner weight by 2 so that the scale doesn't blow up and 3 stands that are the same height as the spreader board & scale.
I have an 18 gallon gas tank which would be about 108# if it was completely full so I threw in a 60# sack of pre-mix to simulate about a half a tank.
And the results were pretty darn exciting!!!!! (At least for me.) Results are without a driver.
Left Front: 554
Right Front: 657
Left Rear: 622
Right Rear: 580
Which means this:
Total weight: 2413. Front 50.2% Rear 49.8%
Left side 48.7% Right side 51.3%
Cross weight 53/47%
Left Front: 554
Right Front: 657
Left Rear: 622
Right Rear: 580
Which means this:
Cross weight 53/47%
Great progress. Looks good.
kevin924kevin- Posts : 927
» Carburated LS1... who's done it?
» Anybody with CARB experience?
» Questions about a 350 Carb Install
Page 4 of 4
