Hydro boost install
+16
shokwave30
Oso
Wild Bill
Bluemach1
vt951
Vorsche944
ghostcloak
msmoorenburg
20 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Hydro boost install
If I go with the hydroboost II which i believe is part # 52-7200, can I still go with the 2000 mustang master cylinder or which is ideal?
Oso- Posts : 28
Any chance the writeup on this a couple people mentioned doing has been done or will be done soon?
I'm starting to get ready to consider possibly thinking about getting around to upgrading my un-boosted brakes...
acorad- Posts : 697
acorad wrote:Any chance the writeup on this a couple people mentioned doing has been done or will be done soon?
DO it..... Use the BMW system. Much easier.....
Dawgz83948- Posts : 603
docwyte wrote:How is the BMW system easier?
Compatible with the 944 master. 5/8" tubing works with the metric lines. Remote accumulator. Even the PS pressures and flow are near identical to the 944 power steering system (if you're using it).
Thanks Dawg.
acorad- Posts : 697
ive been trying to decide which way to go and im thinking im gonna with the hydroboost.. but which bmw can i find that system on? anybody have pix of that system installed?
shokwave30- Posts : 68
83-88 BMW 533 I (E28); 635 CSI (E24); 735 IL (E32) There may be others. Mine came from a 633CSI.
https://944hybrids.forumotion.com/gallery/Personal-album-of-v8carreragts/hydroboost-pic_855.htm[url][/url]
v8carreragts- Posts : 332
How is the rear brake bias with the BMW unit? Is it any different than the Ford unit? This is one thing i have been researching alot of, trying to decide between hydroboost or an electric booster for use on a car that will see a fair amount of track time.
Techno Duck- Posts : 447
The brake bias isn't effected because you re-use your original master cylinder.
That sounds like a good option. Wish I'd looked into it. I have the does unit and it works well, but brake bias was affected on the track. Too much to the rear so I installed a tilton adjustable brake bias valve. All is well now.
Mounting remote brake fluid reservoir.
Quick question. I am trying to install my strut tower brace, and I needed to install a remote reservoir because the ford hydroboost reservoir in it's stock location interferes. The problem is, now I don't know where to mount a remote reservoir. So I guess my question is, and I think I already know the answer... Does the remote reservoir have to be mounted higher than the master cylinder? I'd post pics but the site isn't letting me paste. Ugh.
zeusrotty- Posts : 444
I was able to fit the KLA strut tower brace by using a roughly 1/2" aluminum spacer in between the strut tower bracket and the actual rod (brace). This pushes the brace farther forward (away from the stock Ford reservoir). You can achieve the same thing with washers.
If you opt for remote reservoirs, yes they have to be higher than the master cylinder.
Spacers look like they will work, as long as the bar clears the hood. Lol
I went with remote reservoirs; they are a pain to bleed but the work well, I got them mounted well above the MC.
These are generic motorcycle reservoirs and fittings from Ebay.
pormgb- Posts : 186
So it all clears the motor and the master, but Ill have to cut out another cross section of the hood to get it to work. Otherwise I'm back to remote reservoirs. I don't have room to put the reservoirs where you did. I have a bunch of coil packs there. I'm running out of room!
hydroboost
Just got the kit from TPC. Great kit. Fits perfect. no Problems
had to get done the weekend. having hand surgery so things will slow a little.
Again great Kit
Again great Kit
Buddy2147- Posts : 10
Page 2 of 2 • 1, 2
Page 2 of 2
