» SBC conversion without hood scoop
Hydro boost help EmptyThu May 16, 2019 1:46 pm by sharkey
» ABS brakes won’t bleed
Hydro boost help EmptyWed May 15, 2019 7:04 pm by knucklehead12
Hydro boost help EmptySat May 11, 2019 10:55 am by Rich L.
Hydro boost help EmptyWed May 08, 2019 3:15 pm by lamrith
» Will this throw out bearing work?
Hydro boost help EmptyWed May 08, 2019 2:48 pm by Admin
» LS Truck engines
Hydro boost help EmptyWed May 08, 2019 1:42 pm by Admin
» Did anyone do a before and after weight?
Hydro boost help EmptyWed May 08, 2019 9:12 am by chrenan
» LF: completed kit or mostly complete
Hydro boost help EmptyMon May 06, 2019 12:36 pm by gamman
» Tuner in Houston
Hydro boost help EmptyThu May 02, 2019 3:25 pm by JW1970
» k & N filter and intake boot
Hydro boost help EmptyTue Apr 30, 2019 8:08 pm by JW1970
May 2019
6789101112
13141516171819
20212223242526
2728293031
Hydro boost help
Hydro boost help Empty Hydro boost help
Post  dsrracer on Mon Oct 17, 2016 1:24 pm
I've bled the hydraulic system and the level has stabilized. No noise. I've bled the brakes with a pressure bleeder. Now the brakes are on all the time. I can overcome it with the engine on a lift but can not turn any of the wheels by hand. Any ideas are very welcome. I thought I was almost ready for the first drive.
dsrracer
dsrracer
Hydro boost help Empty Re: Hydro boost help
Post  sharkey on Mon Oct 17, 2016 2:46 pm
does it change between running and not? all 4 wheels or just 2? only thing that comes to mind is the pushrod from the pedal to hydroboost is too long, or the pushrod in the hydroboost to the master cyl is too long. this would keep the brakes applied.
Post  dsrracer on Mon Oct 17, 2016 4:03 pm
It doesn't change between running and not running. It is all 4 wheels. I cracked a fitting quickly and let the pressure off. First rear - rear wheels freed up, then the front- front wheels freed up. I applied the brakes and it locked up and stayed locked again. I'll check the link length to the pedal. The link to the stock 944 MC was a TPC part. I didn't check its length (not sure what the length should be) but I can disassemble and check it.
dsrracer
dsrracer
Post  sharkey on Mon Oct 17, 2016 4:13 pm
the pushrod between the pedal and booster should allow for some freeplay in the pedal. basicly you should be able to unhook the pushrod from the pedal without fighting pressure from the booster.
Post  dsrracer on Mon Oct 17, 2016 4:48 pm
I'll check it- thanks!
dsrracer
dsrracer
Post  sharkey on Mon Oct 17, 2016 6:54 pm
if that seems ok unbolt the master cylinder from the booster with everything hooked up while the brakes are locked up. if while unbolting the brakes free up and/or the master cylinder is being pushed off of the booster, something is wrong with the pushrod length coming out of the booster
Post  Jasonscottw on Mon Oct 17, 2016 10:54 pm
Seems like a pushrod issue if there isn't a difference between engine running vs. not running. What was the length of the pushrod? I milled two of them, so I can compare to the one that is not installed-
Jasonscottw
Jasonscottw
Post  dsrracer on Sun Nov 06, 2016 4:55 pm
I've continued to have brake problems since the initial post. I thought I could fix them and have tried several things without any success.
I sent Kent a question but thought Id share the problem for any advice.  I have extended the rod outside of the unit toward the pedal and raised the front end pretty high and bled the system as recommended. With everything  cold I have no braking force applied. I live about a mile from a major road and I'm able to drive slowly (15 mph) the entire way without touching the brakes at all but within the mile they are dragging without ever even touching them. After turning around I am unable to return the mile without the brakes dragging heavily- again never touching them even once. I crack the brake lines which frees them and I drive home. Once I get home they are clamped on again and I can't push the car. After cooling they free up. Again, this without having ever applied the brakes. I observe no movement of the pedal- it stays out where I left it whether the car is running or not.
When assembling the master cyl to the adapter block it compresses the mc cyl approx .66. It is extended into the counterbore of the aluminum block and hits the forward face of the hydro boost, so it's not hanging up 'early' in the adapter block. I'm wondering whether this is closing the ports to the reservoir and trapping the fluid in the brake line during the assembly process.  It's clearly a function of driving (and the hydro boost running) and not of brake application. Hopefully someone has an idea. Btw the block thickness is 1.255 - I don't know whether that the correct thickness or its too short. There is nothing in the old vacuum booster that would preload the shaft at all during assembly. Thoughts?
dsrracer
dsrracer
Post  dsrracer on Sun Nov 06, 2016 4:57 pm
BTW- the push rod length was 4.8 in. I forgot add that.
dsrracer
dsrracer
Post  dsrracer on Tue Nov 08, 2016 4:31 pm
I finally got the brakes working flawlessly. With a long conversation with Kent we determined there was a sleeve in the hydroboost that was stopping the MC from completely extending (thanks Kent!).
First drive of about 15 miles was flawless. I'll do a shakedown of all bolts and clamps now. I used to race SCCA and there seems like there is always something that you leave loose or vibrates loose but I'm super excited with the conversion, the quality of parts from TPC and the technical support. Anyone thinking about taking the plunge should do it!
dsrracer
dsrracer
