bmw hydro boost bomb "blew"
+3
zeusrotty
tkrame944
7 posters
i am running an ls1 with stock pump with the bmw hydro boost set up, and i just got the car fired up for the first time today. first start up was for about a minute and all was well i didnt touch the therottle just let it idle, the next start up i reved it up a bit and after a few revs it started making funny sounds and out of a valve pointed down on the bomb shot out a punch of very frothy atf, i looked in the resiviour and it was also very frothy. would anyone know what would cause this?
tkrame944- Posts : 101
Re: bmw hydro boost bomb "blew"
frothy is heat or air. Was the part that blew out tightened all the way?
zeusrotty- Posts : 444
it was definantaly air, it wasnt warm at all, and no parts fell off here is a picture of where the oil leaked from.
this is a veiw from under the bomb
i refilled the resivour and blead out all the air in the bomb, and when i fired it back up it instantly started to drain from the same place, but this time no froth. nobody else ever had this happen?
Its actually the accumulator. It sounds like it isn't sealing. Is there an o ring?
The green that you can see in the picture is an o ring, it is not really doing anything at all its just sitting there
That looks like where the pressure line to the rack is supposed to go.
I have checked and rechecked my routing and i have it correct, the area where it is leaking has nothing to attach a line to.
I checked mine and it feels like there is a cap of some sort in the center of the place yours is leaking.
I can't see mine the way its mounted but if you still need I will stick my phone in to get a picture of it later today. Your valve body willl need service or replacement at the least.
Pat
Pat
Patb- Posts : 46
It did seem like there was a cap there at some point . How would i and where would i get the stuff to rebuild it?
I have no idea where to get the rebuild stuff if it is even available, i'd replace it.
Patb- Posts : 46
Thats what im thinking too, you know a good place to buy one?
If the ATF is coming out of the area marked by the number 5 in that diagram, your diaphragm might have failed. When the diaphragm fails ATF will fill this area; it could leak from the Nitrogen fill port?
If the failure happened suddenly the Nitrogen would mix and aerate the ATF.
Start the car, let it idle for 10 seconds, shut the car down, pump the brakes....the accumulator, when functioning correctly, should afford you 8-10 pumps and then become a hard peddle.
When i hit the brake petal you can hear air being pumped out of the accumulator.
That part of the regulator is suppose to be covered. There is a spring and spool valve under there. You probably need another regulator. A new one is insanely priced so I would get a used one.
v8carreragts- Posts : 332
Bummer that happened, definitely need a replacement regulator. I am pretty sure the part number is this 34-33-1-153-303-BOE. Cheapest (not used) is what I saw here (almost 5 bills, most other places are 800) [You must be registered and logged in to see this link.]
There are plenty of BMW dismantlers out there, I only saw a complete sytem on eekbay for $799, not exactly attreactive. These come up frequently there if you are patient. Good luck with the search.
Mike
Mike
I found one on ebay with the booster for nearly $200 i guess thats my best bet. A nice kick in the teeth for already having that stuff
