Proper Torque Tube Alignment .pdf
The linked .pdf file describes the Porsche recommendation for properly aligning the torque tube in the 944. This info is straight from the Porsche 944 factory service manual.
SBC TT Adapter Alignment Instructions
Here's the .pdf for the C5 BH Adapter...
C5 BH Adapter Instructions
gt1scca- Posts : 795
Re: Proper Torque Tube Alignment .pdf
EDIT:
I added the .pdf link above for the C5 BH Adapter Instructions...
TT holes
Thanks Greg.
I think a few of us discovered the upper driver's side TT flange bolt hole being off on a few cars.....
Yes we did...
Nothing a drill bit can't fix... [You must be registered and logged in to see this link.]
Not mines....
Oktober
I still say my car was on the assembly line during Oktoberfest.
.....wish there were a drunk emoticon
maybe hungover emoticon works just as well
All 4 of mine had to be slightly drilled. Perhaps 1/16". They were too wide at both top and bottom for the studs on the plate to go through without interference.
On the plus side, my driveshaft is 5.70" from the flange surface, which is within the tolerances found of various documents, so I'm not sure I ended up moving the driveshaft when I pulled the I4.
endrnet- Posts : 129
5.70", Awesome.
Roll with it dude.
...Right where it needs to be.
Roll with it dude.
» Proper Torque Tube Alignment .pdf
» New convert under way
» Forward fitment of V6 to keep stock brakes - doable ?
