Garage queens EmptyToday at 4:14 pm by SpeedRacer11
» Rear coilover suspension setup
Garage queens EmptyToday at 3:30 pm by ThomasJoseph315
Garage queens EmptyYesterday at 10:12 am by Nath1142
Garage queens EmptyMon Apr 22, 2024 7:22 pm by lowform
Garage queens EmptyMon Apr 22, 2024 7:12 pm by lowform
Garage queens EmptyMon Apr 15, 2024 7:28 pm by JW1970
Garage queens EmptyMon Apr 15, 2024 6:59 pm by JW1970
Garage queens EmptyMon Apr 15, 2024 9:51 am by Raymond-P
Garage queens EmptyFri Apr 12, 2024 3:07 pm by Rob44
Garage queens EmptyWed Apr 10, 2024 10:09 pm by LS982
Garage queens
+6
RobotMachines
jws
gdopnt
10 posters
Page 1 of 2 1, 2  Next
Garage queens Empty Garage queens
Post  gdopnt Wed Feb 27, 2013 10:08 pm
I have 2 944s I bought the blue 87s which be receiving the conversion. The plan is a street car project. A 2000 Trans Am donated the motor and accessories. The motor has 62k so I will wait to rebuild and keep cost down. Currently working on getting the motor out. The bolts are all loose just need to start removing the electrical. The car has turbo brakes and I plan to use hydro boost. I have been reading a lot of the posts and will be needing all of them. I will update my project as I go.
This one is a good running, good shape and wanted to leave it alone.
gdopnt
smkn951 likes this post
Garage queens Empty Re: Garage queens
Post  87-944S Wed Feb 27, 2013 10:29 pm
Welcome! Always good to see another conversion underway. Can you re-post your pic? It just shows your local path.
Post  jws Thu Feb 28, 2013 10:36 am
With 62k miles on the engine I wouldn't consider a rebuild for just a street cruiser. That engine is going to be fine. Eric is using a used engine for my conversion. No worries! Very Happy
jws
Garage queens Empty Motor is out
Post  gdopnt Wed Mar 06, 2013 3:25 pm
Removing the motor wasnt too bad, a lot of up and down being by my self. I lowered the motor to the floor and the 21 inches in height from the book was wrong so i lifted the car with the hoist and pulled the motor out the wheel well.
gdopnt
Garage queens Empty torque tube shaft
Post  gdopnt Thu Mar 07, 2013 10:16 pm
I measured the torque tube to the end of the shaft and it is 5.626"
gdopnt
Post  gdopnt Wed Apr 10, 2013 9:05 pm
This is what I have on the pilot bearing install. The crank end was 15mm deep and the cup and bearing were 25mm total so the cup sticks out 10mm.
The cross member was trimmed a little for clearance. the oil pan needed a rubber mallet on the inside of the pan to clear the tray.
[You must be registered and logged in to see this image.][/url
Sorry no fly wheel bolts , they have become slow to get because there metric
gdopnt
Garage queens Empty First test fit
Post  gdopnt Wed Apr 10, 2013 9:37 pm
Engine is installed.
gdopnt
Garage queens Empty shaft to bearing
Post  gdopnt Wed Apr 10, 2013 10:03 pm
How it started
And the purpose for my test fit. Adjusting the shaft was not so hard. [You must be registered and logged in to see this image.]
Next thing is to pull it all out!
gdopnt
Post  Porch Thu Apr 11, 2013 9:42 pm
Looks great! Keep up the good work.
Post  gdopnt Mon Apr 15, 2013 7:34 pm
what happens with side of the oil filter housing?
gdopnt
Post  Admin Mon Apr 15, 2013 8:17 pm
You screw on the oil block off plate from the factory pan. Make sure you use a new gasket as well.
What part did you have to move with a rubber mallet?
I test fit/build these pans on a LS1 motor with a full windage tray in place as well as I build them without a gasket in place so they will have a little more room once the are installed on the motor permanently.
Post  gdopnt Mon Apr 15, 2013 10:26 pm
Oil filter side, I moved back and forth enough to make a mark just in front of pen.
The extended bolts that were sent for the cross member are the wrong size, the black which were sent are 1.75 and the silver ( i only have two so far) are 1.50 thread pitch.
Little things really kinda like the block off plate walking away with the stock oil pan I sold.
gdopnt
Post  Admin Wed Apr 17, 2013 9:58 am
Thanks for the heads up on the bolts, I went and checked my inventory and the wrong parts were sent to me. I should have the new bolts coming in tomorrow, I'll get a set to you ASAP!
Garage queens Empty Engine bay paint
Post  gdopnt Mon May 27, 2013 6:32 pm
I went to a Chevy dealer and found Night race blue metallic from a new corvette, its darker than the Porsche blue. Complete color changes are harder so I wanted to keep this part simple. All paint is base coat clear coat.
gdopnt
Garage queens Empty Garage queens update
Post  gdopnt Tue Aug 13, 2013 9:46 pm
Since my last post. I had the motor rebuilt and the heads done, new valve train and cam from EPS.
A new double roller chain. New SLP oil pump this pump is made to be in front of the double chain no shims
The oil pick up tube mount did touch the cam cover
Less than 2 minutes grinding to correct
gdopnt
Post  gdopnt Tue Aug 13, 2013 10:39 pm
After
The back side of the oil pump
The LS6 PCV valley cover
I had the bolt holes line board up 1/2 inch and then a plate welded in on all four sides. They opened 1mm from welding but that can't be all too bad because they did not just slide in being raised.  Longer bolts will be needed.  The rear A arm spacers will not  be installed.
Clearenced in the rear for the A arm because I raised A arm mount holes up. I cut the same angle 1/2 up.
2000 Ford hydroboost with TPC mount plate with the rod threaded for the porsche bracket. Although I have not cut off the one side of the fork  for those who look close.
I purchased a PAINLESS harness and have a camaro ecm also ordered TCP long tube headers.
BTW- Thank you Eric for all the help and  parts
gdopnt
Garage queens Empty Remote bleeder
Post  gdopnt Sat Aug 24, 2013 8:33 pm
Installed a remote line for bleeding the clutch that is no where I want to reach later.
Found it better to drop the motor down on the creeper and I didnt have to raise the car any more than where it was. Pushed right through the fender well.
Motor finally back in
Also installed hydroboost
gdopnt
Garage queens Empty Headers
Post  gdopnt Wed Aug 28, 2013 9:40 pm
These look nice.
Just as easy to install as any thing else.
gdopnt
Post  RobotMachines Thu Aug 29, 2013 8:54 pm
Shoehorned Very Happy
RobotMachines
RobotMachines
Garage queens Empty Steering shaft
Post  gdopnt Wed Sep 18, 2013 8:52 pm
Steering shaft Lengthened 1/2 for my 1/2 cross member spacers. Scribed  a center line and cut in half. Machined a sleeve to lengthen  a 1/2 and scribed a center line.
Drilled and taped with allen heads for test fit.
After a test fit it was welded.
Hardened pins were inserted and welded in.
gdopnt
Garage queens Empty Upright bolt and steering shaft
Post  gdopnt Wed Sep 18, 2013 10:13 pm
The upright bolt was turned around to clear the steering knuckle. Then the shroud on the alternator was trimmed for the bolt.
gdopnt
Garage queens Empty Steering shaft length
Post  simon123 Fri Sep 20, 2013 6:49 am
This is from experience.
When I worked with Xschop on my steering shaft we found that the length should be increased by an amount LESS than the amount you drop the cross member.
Imagine the steering shaft to be the hypotenuse of a right triangle, the perpendicular is the dimension that increases when you drop the cross member, therefore the hypotenuse will increase some amount less than the drop. Can't remember exactly the amount used but I believe we settled on 1/2" extension for a 3/4" cross member drop.
Don't forget to retain the U joint clocking.
simon123
Post  944convert Fri Sep 20, 2013 7:20 am
simon123 wrote: but I believe we settled on 1/2" extension for a 3/4" cross member drop.
That's what Rob says here:
Post  gdopnt Fri Sep 20, 2013 11:26 pm
Its all a learning process and I wasn't in on the geometry but I used his drawing so what next is test it. If its wrong I'll do it over.  I have a machinist and welder who dont mind helping and at times we labor trade. Its nice that this information is here but not nice if parts are left out.  Thats why I show my progress counting on feedback to fill in what is not out in the open.
gdopnt
Garage queens Empty Still moving
Post  gdopnt Mon Jan 06, 2014 10:24 pm
Slow posting but moving along. The motor is oil primed all fuel connections done. Debating the position of the key and computer power. I pulled power right from the switch but with my electrical experience decided to go back to the DME. Yes the most unpopular relay in the bunch, reason being the position in the ignition switch. The DME gives power in the #2 position of the switch and tapping in to the red black would power the computer in the #1 position. I weeded out the lines of the DME so only power coming out would go to the pink computer wire. Of course subject to change. Goal at this point is to fire the motor, then move on.
gdopnt
