Today at 6:52 pm by chrenan
Today at 5:45 pm by AMFCSL
» Tpc LS adapter plate
Today at 5:41 pm by jimbag
» Headers, headers, HEADERS!
» Electric brakes
Proper Torque Tube Alignment .pdf
Post  gt1scca on Fri Jun 26, 2009 2:13 am
The linked .pdf file describes the Porsche recommendation for properly aligning the torque tube in the 944. This info is straight from the Porsche 944 factory service manual.
SBC TT Adapter Alignment Instructions
Here's the .pdf for the C5 BH Adapter...
C5 BH Adapter Instructions
Re: Proper Torque Tube Alignment .pdf
Post  gt1scca on Mon Aug 10, 2009 10:06 pm
EDIT:
I added the .pdf link above for the C5 BH Adapter Instructions...
TT holes
Post  xschop on Mon Aug 10, 2009 10:12 pm
Thanks Greg.
I think a few of us discovered the upper driver's side TT flange bolt hole being off on a few cars.....
Post  gt1scca on Mon Aug 10, 2009 10:26 pm
Yes we did...
Nothing a drill bit can't fix... [You must be registered and logged in to see this link.]
Post  944-LT1 on Tue Aug 11, 2009 12:33 am
Not mines.... Razz
Oktober
Post  xschop on Tue Aug 11, 2009 9:27 am
I still say my car was on the assembly line during Oktoberfest.
.....wish there were a drunk emoticon
maybe hungover emoticon works just as well pale
Post  endrnet on Tue Sep 22, 2009 10:38 am
All 4 of mine had to be slightly drilled. Perhaps 1/16". They were too wide at both top and bottom for the studs on the plate to go through without interference.
On the plus side, my driveshaft is 5.70" from the flange surface, which is within the tolerances found of various documents, so I'm not sure I ended up moving the driveshaft when I pulled the I4.
endrnet
Post  gt1scca on Tue Sep 22, 2009 11:48 am
5.70", Awesome.
Roll with it dude.
...Right where it needs to be.
