Scryfst '88 LS1, thought I'd share some updated pics
+9
RS Technic
bluejk09
skywalker01
scryfst
13 posters
Re: Scryfst '88 LS1, thought I'd share some updated pics
VERY NICE - Where are you autocrossing??
skywalker01- Posts : 477
Good looking car!
[quote="skywalker01"]VERY NICE - Where are you autocrossing??[/quote
The pics posted are at Tire rack's test track in South Bend, IN. I've been racing events between Chicago and Indianapolis.
And thanks for your complement.
Very nice!
What wheels are those, what are the measurements?
acorad- Posts : 697
CCW wheels948 wrote:Very nice!
18x10 et41
18x12 et48
No spacers
Hoosier A6 295 & 335
Looks great! How does it track with the staggered tires. Everything I read says to keep it square but If I run the broadfoot flares, I want to go wide in the backscryfst wrote:CCW wheels948 wrote:Very nice!
18x10 et41
18x12 et48
No spacers
bluejk09- Posts : 18
I autox the car and needed as much rubber on the back as possible. My engine makes 392hp at the wheels and would over rotate often out of tight corners. (Probably because of my driving style, HUGE right foot)bluejk09 wrote:Looks great! How does it track with the staggered tires. Everything I read says to keep it square but If I run the broadfoot flares, I want to go wide in the backscryfst wrote:CCW wheels948 wrote:Very nice!
18x10 et41
18x12 et48
No spacers
Have yet to get the car on a road coarse. I can say that if you plan to track the car a square setup lends itself to tire rotation much better. Also 18x10's will fit under stock fenders with 285's, just need the correct backspacing.
Hope this helps.
You definitely want a square setup. I run 17x9's with 275-40-17's all the way round at the track. Car is very neutral and I can point it with the throttle.
I'd wager my setup would work out well on an auto-x as well...
wheel size
Hello, nice job on the car. With your current wheel size, did you have to use any spacers. Those are the sizes i would like on my car. Sorry reread no spacers needed.
kevin924kevin- Posts : 927
Wow. Very nice!
Very classy without being over done.
RS Technic- Posts : 73
Beautiful work. Love your attention to detail in the engine bay. Inspiring.
majormojo- Posts : 82
Upon closer observation it looks like you are using a vacuum brake booster. Am I seeing that correctly? If it is, how did you do it and what is the part #?
Nope, manual brakes.RS Technic wrote:Upon closer observation it looks like you are using a vacuum brake booster. Am I seeing that correctly? If it is, how did you do it and what is the part #?
Ahhh, That must be a Black mount plate. Very nice contrast
Are you using the stock MC?
Good to see another fan of red in the engine bay, excellent work, looks fantastic!
Very nice looking car! Enjoy it!
What engine modifications have you done to make your stated power? I'm guessing more than external bolt ons.
What oil pan/system are you using? Any issue with oil pressure? I'm more of a road track guy, but have seen the oil pressure light start to glow at times
money pit 951- Posts : 101
I live about 15 miles from Grissom air base where that autocross pic is taken. Really nice attention to detail love your car and the color great job.
kelleysj- Posts : 194
Yes, However I have a few wildwood MC's that I'm going to try. Clutch pedal stroke is not what I'd like since installing Spec stage 3+ clutch.RS Technic wrote:Ahhh, That must be a Black mount plate. Very nice contrast
money pit 951 wrote:Very nice looking car! Enjoy it!
Using the RH pan and pick-up.
Ported and polished oil pump.
No issues with oil pressure to date.
Engine:
Stock bottom end ( '04 LS1 )
Patriot 5.3L CNC heads (Flow benched at 292 @ .550)
Howards cam
Harland roller rockers
BBK 85mm intake and TB ( Ported and polished )
RH Headers
Bosch Blue demon injectors
Everything that could be gasket matched has been.
Tune by Speedlab
Dyno results:
392 crwhp
368 crwtq
Nice work on the engine! Sounds like we have a similar setups. I was going for a flatter power curve so my parts section was slightly different, but we're very close. I'm sure it's a blast to autoX. Enjoy!
Just curious, what does your car weight?
» Ball joint and strut mount questions.
» Thought I had an extra oil filter
» I always thought the v8 Conversion was the way to go
