928 Fuel line obstacle...damn Germans
At the lower pass. side firewall the hard lines come up and the feed line from the fuel pump is closest to the pass. fender. The dilemma is the connection sizes are backwards from any other car I've worked on.....
Re: 928 Fuel line obstacle...damn Germans
For the 5/16 " feed side you can use a Dorman part number 800-079
Also the Dorman part number 800-078 looks the same but has 16mm threads and 3/8 line out
It has a 14mm female thread and a 5/16 " tube out let.
You will need a dorman part number 800-085 to connect to the filter inlet
It has a 5/16" line in on the barb side and 3/8" quick connect for the fuel filter side
Dorman part number 800-082 has 3/8" barb to 3/8" quick connect
You will need to have someone with a special tool push on the plastic 5/16" fuel line on both fittings to make the length hose you need, then it is just a plug and play deal.
Props to Eric (admin) for the fuel filter/reg solution...
