LS Swap - Fuel and Auto Trans line question!
Hey all!
So I've finally got my LS in and running, however I need to plumb in the trans and fuel lines. When I got my shell, the lines were cut at the firewall, however they are in good condition so I plan on still using them. My question however.. I can trace two to the auto trans, however there are three more.. obviously one is for a fuel feed, another for fuel return.. however I'm stumped on what the remaining one could be for and where to plumb it, or if it's needed at all?
Is there an in and an out for the trans, will it matter which way I plumb it into my trans cooler?
Any help would be greatly appreciated!
Many thanks in advance.
andypandy- Posts : 5
Re: LS Swap - Fuel and Auto Trans line question!
Fuel tank vent line for the charcoal filter?
I use a seperate trans cooler from radiator. It doesnt relly matter how you hook into stand alone trans cooler . If your using radiator it dont really matter either because they go into radiator on the pass side which is the cool side of radiator. Auto transaxles on a 944 run cool because its in the back and dont get to much heat soak from engine attributing to the longevity of it. Im pretty sure admin has done a auto trans conv on a LS but I havnt heard to much from him how it worked out.Ive got a sbc conv with a auto transaxle and have had only 1 issue with flexplae that bolts to converter but is an easy fix.andypandy wrote:Hey all!
stu wright- Posts : 312
