Misfire?  Strange things happening... EmptyToday at 4:14 pm by SpeedRacer11
» Rear coilover suspension setup
Misfire?  Strange things happening... EmptyToday at 3:30 pm by ThomasJoseph315
Misfire?  Strange things happening... EmptyYesterday at 10:12 am by Nath1142
Misfire?  Strange things happening... EmptyMon Apr 22, 2024 7:22 pm by lowform
Misfire?  Strange things happening... EmptyMon Apr 22, 2024 7:12 pm by lowform
Misfire?  Strange things happening... EmptyMon Apr 15, 2024 7:28 pm by JW1970
Misfire?  Strange things happening... EmptyMon Apr 15, 2024 6:59 pm by JW1970
Misfire?  Strange things happening... EmptyMon Apr 15, 2024 9:51 am by Raymond-P
Misfire?  Strange things happening... EmptyFri Apr 12, 2024 3:07 pm by Rob44
Misfire?  Strange things happening... EmptyWed Apr 10, 2024 10:09 pm by LS982
Misfire?  Strange things happening... Empty Misfire? Strange things happening...
Post  docwyte Thu Aug 23, 2012 8:59 am
So yesterday I started up the car to drive home from work. All was well, normal exhaust note, firing on all 8. About half way home I noticed that the exhaust note had changed and it sounded like all 8 weren't firing.
Same thing happened this morning, car worked fine for half the drive, then started sounding weird like it wasn't firing on all cylinders.
I hate intermittent problems! What should I be looking for, a bad spark plug wire?
Misfire?  Strange things happening... Empty Re: Misfire? Strange things happening...
Post  Admin Thu Aug 23, 2012 10:22 am
Check the O2's , they only start playing a roll in the running once the car goes into closed loop operation. Usually after it warms up good, ( Half of your drive, maybe )
Also check and make sure your MAF is tight, so there is no air by-passing is......
Post  docwyte Thu Aug 23, 2012 10:31 am
Got it, will do. I should be able to see if there's a problem with either by scanning them with HP Tuner, right?
