Yesterday at 9:03 am by chrenan
Fri May 25, 2018 8:34 pm by superman22x
» WTB: 944 Turbo Roller
Thu May 24, 2018 8:32 pm by knight76
Thu May 24, 2018 7:52 pm by matt889
» New here needing help
Thu May 24, 2018 3:45 pm by sharkey
» 5.3 conversion on 88 Turbo
Wed May 23, 2018 11:00 am by kevin924kevin
Tue May 22, 2018 10:36 pm by mryan318
» Clutch Issues - HELP!!!
May 2018
78910111213
14151617181920
21222324252627
28293031
This is cool...
This is cool...
Post  968gene on Sun Dec 06, 2009 6:16 pm
or, this should cool....
I found a Griffin radiator that is being used by the 1/4 guys. the fit is excellent in the stock location and the rad is all aluminum with the inlet and outlet on the correct sides for the LSx conversion.
968gene
Re: This is cool...
Post  Admin on Sun Dec 06, 2009 6:43 pm
Larger Picture?
Size and part number?
link
Post  968gene on Sun Dec 06, 2009 6:47 pm
I think you'll find the price very competitive with a stock (plastic) turbo unit. This one is also 3" thick and fits without cutting anything.
968gene
Re: This is cool...
Post  Bluemach1 on Sun Dec 06, 2009 7:22 pm
Cool. What is the P/N for the one in your picture?
Bluemach1
Summit
Post  968gene on Sun Dec 06, 2009 7:25 pm
2-58185-H
$387.99
Last edited by 968gene on Mon Dec 07, 2009 12:56 pm; edited 1 time in total (Reason for editing : PN and Price)
968gene
Re: This is cool...
Post  Bluemach1 on Sun Dec 06, 2009 7:50 pm
here it is without the filler neck:
Where would the expansion tank go though? (or how would you plumb back to it in its original location?)
Bluemach1
see picture
Post  968gene on Sun Dec 06, 2009 8:57 pm
The one I selected has a threaded port on the driver's side top corner. It is small but should serve as a connection for the stock expansion tank.
968gene
Re: This is cool...
Post  gt1scca on Sun Dec 06, 2009 11:28 pm
Admin wrote:Larger Picture?
Re: This is cool...
Post  modenas on Mon Dec 07, 2009 12:08 am
so is his one thinner than the stock 944 one?? it so it be great with a 944 dual fan and a short water pump for my sbc
modenas
Re: This is cool...
Post  Johnny Johnny on Mon Dec 07, 2009 7:31 am
Why is the one without the filler neck so much more expensive???? pale
Johnny Johnny
Re: This is cool...
Post  944-LT1 on Mon Dec 07, 2009 8:28 am
The one without the filler neck is a different style. The one w/o filler neck is a cross-flow whereas the other is a scirroco style. Also, the w/o filler has 1-1/2" tubes whereas the other is only 1". Thats all I see as to why one is more expensive other than that demand may be lower for the w/o filler neck model.
But probably the tube size is what makes the other so much more expensive. (??)
As a contrast, another model of griffin's is one with 1-1/4" tubes and 2.5" thick and is 530 dollars! So im not so sure.
clearing up a few things...
Post  968gene on Mon Dec 07, 2009 9:57 am
I spoke to Griffin and they agreed the radiator I have will more than do the job. Mine is also a Scirocco style. I had to trim the retaining tabs (bottom, both sides) about 0.5". I am using rubber isolators to bolt the rad down and I have a 1.5x1/8" aluminum strap and a teflon spacer to hold the top in place. This is a "plug and play" as an all aluminum radiator can get for the money.
968gene
Re: This is cool...
Post  Vorsche944 on Mon Dec 07, 2009 5:23 pm
Here is what we did on mine.
Moved the radiator forward 4 inches. Did this by replacing the cross member with the one Eric builds. Cleaned up the area under the hood nose. removed the filler cap and constructed a remote filler. Built a frame to hold the radiator. From the pics you can see how much room we were able to get for the fans and such.
To create the space we got rid of the hood latch and went with hood pins. Here some pics of what we did. We were able to use the following radiator from Summit. $159.
Part Number: SUM-380645
Radiator Style: Crossflow
Overall Width (in): 23.875 in.
Overall Height (in): 16.000 in.
Overall Thickness (in): 1.750 in.
Row Quantity: Single-row
Radiator Finish: Natural
Radiator Material: Aluminum
Transmission Cooler: No
Inlet Location: Upper driver side
Inlet Size: 1 3/4 in.
Outlet Location: Lower passenger side
Outlet Size: 1 3/4 in.
Core Height (in): 16.000 in.
Core Width (in): 20.750 in.
Vorsche944
Re: This is cool...
Post  944-LT1 on Mon Dec 07, 2009 5:32 pm
Vorsche, You dont run an expansion tank anymore then???
Re: This is cool...
Post  Admin on Mon Dec 07, 2009 6:42 pm
We didn't need it any more, There is a catch can on the driver's side about where the ac air dryer was.
Re: This is cool...
Post  944-LT1 on Mon Dec 07, 2009 6:55 pm
Awesome!
Re: This is cool...
Post  948 on Mon Dec 07, 2009 7:34 pm
Admin wrote:We didn't need it any more, There is a catch can on the driver's side about where the ac air dryer was.
Do you still have a high point for the air to bleed into?... after the initial fill and during the life of the fill the entrained air needs to be bled out.
Re: This is cool...
