Hydroboost mounting
Hydroboost mounting
I'm in the process of mounting up my hydroboost, but i've run into a few issues that i'm sure i'm not the first one to hit.
Basically, when the unit is mounted at a ~12* angle in the position where the stock master cylinder would sit, it's too high. The obvious thing to do then is to move it down, but that would seem to change the angle needed at the firewall. Is that correct?
I can just eyeball it from there, but i wanted to make sure my logic was correct first. When i put the hydroboost setup where i think it should go and eyeball the pedal stroke, it seems the master should be almost completely level.
Re: Hydroboost mounting
Which Hydroboost are you using?
Sorry, should have specified. I'm using the Mustang unit.
You are correct. Don't use the Sloan plate position dimension in the tech drawing or the HB will be too high and the pushrod angle will be way off. I made my set-up user adjustable with washers on the bottom carriage bolts to remedy this problem.
Great, thanks!
Now all i need is a way to do a remote reservoir on this darn thing...looks like the reservoir is going to get in the way of my strut tower brace
