Today at 3:06 am by zeusrotty
» Clutch master cylinder
Yesterday at 8:40 pm by Arthropraxis
Sat Jun 16, 2018 9:43 am by JP914
» WTB : Coil over setups !
Fri Jun 15, 2018 2:26 pm by matt889
» For Sale: Turn One Power Steering Pump & F-body conv kits
Tue Jun 12, 2018 10:35 pm by jHo
» For sale $150 Griffin for LS1 LS Radiator swap
Tue Jun 12, 2018 7:51 pm by HGT1
Tue Jun 12, 2018 6:17 pm by AMFCSL
» 5.3 conversion on 88 Turbo
Tue Jun 12, 2018 6:39 am by tsimpson
Mon Jun 11, 2018 10:04 pm by Luke714
» Clutch Issues - HELP!!!
Sun Jun 10, 2018 3:14 pm by sharkey
June 2018
Hydroboost mounting
Hydroboost mounting
Post  speedsterman on Thu Feb 07, 2013 9:43 am
Hello Folks
I am doing a little back paddling and trying to mount the hydroboost unit and had a couple of questions to those that are using hydroboost.
Do I mount the hydroboost at the stock 944 brake pushrod location ?
Are there any clearance issues ? coils, valve cover, shock tower.
What thickness firewall reinforcement plate are you using ?
One more, Does anyone have fitting numbers if I go with AN adapters ?
Thanks in advance for any help.
I did a search of the forum but could not find any definitive specifics on the mounting.
speedsterman
Hydroboost
Post  fliermike45 on Thu Feb 07, 2013 11:11 am
Try again, use the advance search function, the answers you seek are all there.
This topic has been covered a few times.
Re: Hydroboost mounting
Post  Techno Duck on Thu Feb 07, 2013 12:17 pm
Here are some threads i had book marked, i made a little 'fact' sheet for the shop doing my conversion to make there life easier..
http://944hybrids.forumotion.com/t259-hydro-boost-install - Indexing info
http://944hybrids.forumotion.com/t1689-hydroboost-mounting-plate
http://944hybrids.forumotion.com/t1956-hydroboost-fitting-help - Fitting info
http://944hybrids.forumotion.com/t1580-my-latest-project-comes-to-an-end-nearly - General install pictures
http://classicbroncos.com/hydroboost_cobra.shtml
Here are the fittings,
-high pressure hydroboost fitting, from the pump: RUS-648080 18mm x 1.5 O-ring Seal to -6 AN $13.69
-high pressure hydroboost fitting, to the rack: RUS-670530 16mm x 1.5 to -6 AN $4.95
Post  BlueDragonX on Sun Feb 10, 2013 2:08 am
I'm going with Earl's fittings as they're steel. Russell only offers one of the fittings in steel.
Those part numbers are 961956 (18mm x 1.5) and 961955 (16mm x 1.5).
I'm trying to dig up thread sizes for the HB return line and brake lines at the moment.
BlueDragonX
Post  speedsterman on Mon Feb 11, 2013 9:48 am
Thanks for the information. I am trying to locate adapters for the Porsche rack. The banjo adapters that I am finding are sometimes listed as "fuel rail" fittings. The size matches and the machining looks sturdy enough. Any concerns? I think they are on Ebay as Honda fuel rail adapter, 12mm banjo to 6 AN.
speedsterman
Post  BlueDragonX on Mon Feb 11, 2013 12:55 pm
I did a bit more research and pricing for the hydroboost fittings and I ended up going with Hydratech part HBS9102. It comes with two banjo fittings for the in/out pressure sides and an AN fitting for the return. All -6 AN. I was only going to purchase the return fitting but I liked the low profile of the banjos.
As to the rack fittings I've not been able to find steel -6 AN banjo fittings. The bolts are easy - they're 12mm x 1.5 - but all the banjo fittings are -4 AN as they're all intended for use on brake calipers.
The alternative, which I plan to do at the moment, is use Pegasus part 3276-003. I'm not 100% certain this part is correct as I found it here on the board. I'm going to order it and find out.
BlueDragonX
Post  Wild Bill on Wed Feb 13, 2013 10:15 pm
You can use metric ORB to JIC fittings, Pretty sure it was Hydratech.
Dont need to reinforce the firewall IMO
Search my posts, i'm sure I posted my mods and numbers on threads.
Wild Bill
