Shop is having a problem getting my new slave cylinder to bleed.
Basically what happened was I broke the bleeder valve on my slave cylinder and had to take it to a shop to have it replaced. Now they are saying that they cant get the thing to bleed. Anyone know why this would happen? Are they missing something?
zeusrotty- Posts : 444
Re: Shop is having a problem getting my new slave cylinder to bleed.
I know when I first installed my bell housing, I had to hold the slave cylinder up higher than the master cylinder to make it the very top point for an initial bleed to get most of the air out. At least thats how the instructions from the kit builder came. It makes sense and I have never had an issue after that.
I also recall shims being needed on some cars, did you measure yours to see if it was required?
Well I imagine if it needed shims, they would have been in it already. And the shop would have reinstalled them. They were just replacing the slave with another slave. You would think a trans shop would know how to get this done. Hopefully this will help. I have a speed bleeder that runs off of the tire pressure. Maybe I will drop that off to then and see if that solves it. Otherwise what could they have installed incorrectly to cause the pedal to not engage?
zeusrotty wrote:Well I imagine if it needed shims, they would have been in it already. And the shop would have reinstalled them. They were just replacing the slave with another slave. You would think a trans shop would know how to get this done. Hopefully this will help. I have a speed bleeder that runs off of the tire pressure. Maybe I will drop that off to then and see if that solves it. Otherwise what could they have installed incorrectly to cause the pedal to not engage?
I brought my speed bleeder over there and it pumped right up. He just didn't have the right top for the reservoir.
as the old adage goes:
if you want it done right, do it yourself !
944convert- Posts : 253
» How to bleed LS1 w/ 951 radiator?
» Why is it impossible to bleed a 948 clutch?
» Wilwood clutch MC leaking at boot immediately after install/bleed
