Car lift installed, now the real work will begin.
+16
RobotMachines
sbwrench
20 posters
Page 6 of 6
Page 6 of 6 • 1, 2, 3, 4, 5, 6
Re: Car lift installed, now the real work will begin.
Drove it home tonight, very happy!
The clutch/shifter vibration at 2900-3000 rpm is completely gone.
The Audi diesel 5th gear gives me 2500 rpm at 70mph, vs the oem turbo 5th that was giving me about 3000 at 70mph.
From the pic it looks like the gear ratio is about 38:26 = 0.68 as expected, however I thought it would lower my revs more, like to 2250 or so. Oh well!
xchop's short shifter shifts so short I sometimes think I'm not in gear yet! Very solid shifting feel overall. Steering seems much more solid with the new ball joint ends. New shocks and struts feel great.
Did have a weird clunk from the right front wheel/strut area when I turned left into my driveway, I'll check to see if something is loose tomorrow.
Last edited by acorad on Thu Jun 14, 2012 2:04 pm; edited 6 times in total (Reason for editing : mistakes about the Audi 5th)
acorad- Posts : 697
Glad to hear the shifter shake is gone.
Right on! That's been a lot of work.
acorad wrote:Did have a weird clunk from the right front wheel/strut area when I turned left into my driveway, I'll check to see if something is loose tomorrow.
I had this. Turned out to be the front sway bar.
thanks guys! I really love the heavy steel flywheel I went with, maybe not the best for the track but it's perfect around town. Gotta say, I'm really noticing the non-boosted brakes. Pretty sure that'll be my next project...
acorad- Posts : 697
Clunk
What are your lower front suspension arm ball joints like? Before I replaced mine I had a clunk because one was badly worn.
Go hydroboost you will not regret it.
Thanks Mike, I have new ball joints. [edit: Actually, they're not new]
acorad- Posts : 697
The strut mount nut may not be tight enough.
Thanks Anthro, I pulled a lot of stuff apart on the front end, I'll go through it again.
acorad- Posts : 697
Looks like it was right front ball joint. Left side wasn't making noise, but when I pulled it apart the plastic bushing inside was in pieces, so I replaced it as well.
acorad- Posts : 697
Wow, what a difference. No clunks, no noise, no nothing when going over bumps, etc.
acorad- Posts : 697
» Started my conversion
» Inexpensive garage lift review
» Need pic from underneath car with v8 installed
Page 6 of 6
