Car lift installed, now the real work will begin.
+16
RobotMachines
sbwrench
20 posters
Page 5 of 6
Page 5 of 6 • 1, 2, 3, 4, 5, 6
Re: Car lift installed, now the real work will begin.
I've just installed my pilot bearing for the first time. On my first go-round I got mine to .65" and it seamed to stop there. But I peered down in there with a light and saw there was still an obvious gap between the adapter and the shoulder inside the crank. So I hit it with a little WD40 (dubya gee photy) lined this up differently and got a couple of good whacks with a 2lb rubber mallet and it moved further. The end result is obvious full seating of the adapter when peering in there and .45" of protrusion from the face of the crank. I think it's good.
Thanks Rich. I guess I just need a bigger hammer!
acorad- Posts : 697
So a BFH and a BF socket got the PB & adapter to go in another ~0.2", my PB is sticking out 0.405" now, so pretty much perfect.
Also thought I'd include a pic of my repair to the drive shaft end. My next door machinist made up the sleeve and added ~0.3" of extra material on the end for a little longer length. Also tapped a hole in the end so the sleeve can be removed by screwing a screw in. Nice snug fit in the PB.[You must be registered and logged in to see this image.]
acorad- Posts : 697
So, back to the TT bearing with the failed sleeve...
The bearing itself seems fine, I spun it and it's smooth and quiet.
It turns out the TT inner sleeves are two-piece, they're made of a smaller plastic sleeve bonded to the inside of a larger metal sleeve. The plastic sleeve grips the driveshaft and the metal sleeve grips the ID of the TT bearing.
On my car the plastic sleeve failed on the front TT bearing leaving the metal sleeve in place inside the TT bearing, so my machinist friend spun a replacement plastic sleeve out of Delrin. I made a tool out of PVC pipe to push it into place, but that also could pull it out when I was trial-fitting.
The trial fitting went well, the new plastic sleeve is able to be jammed inside the metal sleeve.
Although Delrin doesn't glue too well, there are some glues that work kinda well, so my plan is to use that glue on the final install - it'll work as a lube while installing and, hopefully, belt and suspenders when it dries.
acorad- Posts : 697
Nice work. It's crap vulcanized rubber, at least mine were. I added extra lip to the inset to make sure mine didn't pop out. Would be a great way to jack up the shaft against metal bearing I.D. if they pop out.
I've read about guys having to move their drive shaft a little forward in order to get full insertion of the DS tip into the pilot bearing, and then they use a drill to notch their drive shaft at the trans end so the coupler bolt on the DS can be installed.
However, on my car the existing "notch" for the DS coupler bolt is about 1/2" wide - it's more like the DS splines were milled away in a 1/2" band - it's not a "notch" that was made to fit the coupler bolt. In contrast, the notch on the input shaft to the trans is a real notch, it's the width and shape of the coupler bolt and fits it like a glove.
Is this just my DS? Or are all of them like this?
If it's all DS's, I guess I'm just pointing out that it seems like that 1/2" band with no splines indicates that the P engineers expected there to be pretty significant variability in production and that they wanted to be able to easily adjust the location of the DS (depending on how it lined up in the pilot bearing?) and that the location of the DS does not seem to be anchored by the bolt in the "notch" but rather by the clamping force of the coupler itself.
iow, the "49.5mm +/- 0.5mm dimension from the plane of the TT bell housing to the end of the DS" that I've read about does not sound like it's all that critical after all?
acorad- Posts : 697
Well, I've been super busy at work and just got back to the beast today. Got my new TT bearing in place and am ready to hang the clutch and TT.
This may seem like a dumb question, but I'm having a beotch of a time finding an LS1 clutch alignment tool.
If I can't find one easily, can I just mount the clutch disk and pressure plate but only tighten the PP bolts finger-tight, say, and then align the clutch disk as well as I can by eyeballing it, and then bolt on my TT and drive the driveshaft into place in the pilot bearing and use the DS itself to align the clutch disk?
Then just torque down the PP bolts and away I go?
Would this work?
Would this work?
acorad- Posts : 697
I did that when I put mine on.... It was fine
acorad wrote:I'm having a beotch of a time finding an LS1 clutch alignment tool.
You want a porsche 944 clutch alignment tool though. This is also the same as Ford Ranger, Dodge, Mazda Pickup, and many mopar applications. Surely your local parts house will have a tool for one of these or any tool with 23 splines x 1 inch diameter.
But yeah, I dont see any reason why you couldnt do it that way except for the pain it may be.
The Napa store in Thousand Oaks has a alignment set for $30. Or you could probably drop by and order one.
You need dorman #14503.. I went to advance auto parts, they had to special order it but it came in the same day.
948inVA- Posts : 224
I got one from an Oriely parts store and it was in stock for about $6 if I remember correctly. Sorry I can't get you the part number as vacuum wrap got tossed.
Tehone- Posts : 84
Thanks guys, I'll try to find a 23 spline 1" alignment tool locally.
acorad- Posts : 697
Is it wise to throw a little lube on the drive shaft splines?
acorad- Posts : 697
I've been advised to do it very sparingly, with high melting point grease.
And none on the female splines of the clutch disc, else in use it may get to the disk itself.
944convert- Posts : 253
I always do. I just use Moly although theres a marine grade that would be nice since the splines are somewhat open to road conditions.
BTW, both BMW and Porsche recommend it during clutch service.
acorad- Posts : 697
Where else should I lube, drive shaft end where it inserts into the pilot bearing and also throwout bearing face where it contacts the pressure plate fingers?
acorad- Posts : 697
Clutch in, TT in place, drive shaft in place.
It's so nice finally using the ratchet to tighten stuff, instead of loosen.
acorad- Posts : 697
Glad to see things are moving along and you got a lift!
22lambo- Posts : 15
Replaced worn out pin on my shifter with a cap head screw and some thrust washers
and, since I sheared the stud off on my trans linkage, I replaced the whole linkage with some heims.
acorad- Posts : 697
Is the shifter rattle gone now?
Pretty much the $60,000 question. I'll let you know when I get the trans in and the whole shebang back on the road!Arthropraxis wrote:Is the shifter rattle gone now?
acorad- Posts : 697
Got the trans in today, not nearly as much of a PITA as I thought it would be.
acorad- Posts : 697
Only dropped the trans off the trans jack onto the concrete floor once.
acorad- Posts : 697
» Started my conversion
» Inexpensive garage lift review
» Need pic from underneath car with v8 installed
Page 5 of 6
