Porsche Oil pressure sending unit
Dose anyone know what the thread is on the unit? I'm gonna try and use the original oil pressure gauge
msmoorenburg- Posts : 75
Re: Porsche Oil pressure sending unit
944.........M18 x 1.5
LS, 4.8, 5.3, 6.0.........M16 x 1.5
LT..........?
LT..........?
lt is 1/4-18
I looked everywhere and could not find an M18 x 1.5 Female to 1/8 NPT female to relocate the 944 sender, so just went with a ported oil filter adapter for the aftermarket sensor.
I was hoping to keep the stock gauge but the sender is $65~ so it sounds like autometer time
New stock sender should not cost more than 25 bucks, you can get them from Summit and others, lots on eekbay.
I just drilled and tapped mine to 1/8" NPT... Really!
Wild Bill- Posts : 121
» Can I use a Fuel Level Sending Unit For 944 in a 1978 924
» Oil Pressure sender adapter
» PSA!! I found a VDO Temp Sending Unit with LS Threads!
