Can I use a Fuel Level Sending Unit For 944 in a 1978 924
Can I use a Fuel Level Sending Unit For 79-84, 87-88 Porsche 944 in 1978 I am just looking to repair it on the cheap?
I am 17 and new to this so I can not just upgrade to a 944
satin_black- Posts : 2
satin_black likes this post
OR this one?
Fuel Level Sending Unit For 85-95 Porsche 944 968 CW24F2 Fuel Level Sending Unit on eBay?
fuel tank sender
your 78 takes a sender from 76 -85 944. - they all had a metal tank, they went to a plastic tank after 1985
they have gotten real expensive, I have a new one i would sell for 300, most are 350 up. hard to find a good used one. they are held in from the top with screws. you might take out there is a fine wire inside that usually breaks. good luck, LARRY - ACAR24
acar24- Posts : 2
» Needing a fuel sending unit from an 83' NA
» Oil Pressure Sending Unit
Today at 11:31 am by Raymond-P
