Today at 12:30 pm by sharkey
Today at 8:54 am by Rich L.
Yesterday at 5:04 pm by AMFCSL
» Transaxle rebuild
» Hello, Gentlemen.
» alignment specs
Porsche Oil pressure sending unit
Post  msmoorenburg on Fri Aug 20, 2010 1:52 pm
Dose anyone know what the thread is on the unit? I'm gonna try and use the original oil pressure gauge
msmoorenburg
Re: Porsche Oil pressure sending unit
Post  xschop on Fri Aug 20, 2010 2:00 pm
944.........M18 x 1.5
LS, 4.8, 5.3, 6.0.........M16 x 1.5
LT..........?
Post  msmoorenburg on Fri Aug 20, 2010 2:02 pm
lt is 1/4-18
msmoorenburg
Post  xschop on Fri Aug 20, 2010 2:04 pm
I looked everywhere and could not find an M18 x 1.5 Female to 1/8 NPT female to relocate the 944 sender, so just went with a ported oil filter adapter for the aftermarket sensor.
Post  msmoorenburg on Fri Aug 20, 2010 2:11 pm
I was hoping to keep the stock gauge but the sender is $65~ so it sounds like autometer time
msmoorenburg
Post  87-944S on Fri Aug 20, 2010 6:05 pm
New stock sender should not cost more than 25 bucks, you can get them from Summit and others, lots on eekbay.
Post  Wild Bill on Sat Aug 21, 2010 7:04 pm
I just drilled and tapped mine to 1/8" NPT... Really!
Wild Bill
