Working on Hooker Header mod - what is this piece on the block?
This sticks out both sides of the block near the flywheel - any idea what it is, what it's used for and, more importantly, can it be ground down a bit? It's getting in the way of the modified Hooker driver side header I'm working on.
Johnny Johnny- Posts : 164
Get the grinder out
I think it is for a reverse rotation starter. You know these engines are put in the Australian Holden Cars.
I will double check my block to see if it is on the Iron 5.3l
Although who the hell knows, could be something to do with the transverse mounted cars?
Re: Working on Hooker Header mod - what is this piece on the block?
I believe its an undrilled untapped boss for a mechanical clutch linkage. GenI block had a threaded hole about there as well did all the LT engines. Maybe they carried that over to the LS series? Regardless, it looks fine to grind!
[You must be registered and logged in to see this link.][You must be registered and logged in to see this image.]
» pics of Hooker #2312 headers
» Headers, headers, HEADERS!
» Modifying Hooker 2312 headers to fit LSx in 944 engine bay
