» Tpc LS adapter plate
» Headers, headers, HEADERS!
Quick bell housing question - 1 piece MT or 2 piece?
Post  rooster on Sun Jan 01, 2012 11:03 am
Hey folks,
I've finally got my LS1 lift out and need to start sourcing other parts. I found a 1-piece MT C5 bellhousing locally for $100 which I thought was going to work, then I found this thread that seems to say it requires a new geared starter in order to work:http://944hybrids.forumotion.com/t346p15-c5-bellhousing-differences?highlight=bellhousing
Has anyone used the stock starter and the MT 1-piece BH? I found a 2-piece BH also but it's more money and not local. Thanks in advance for the help.
-Andrew
rooster
Re: Quick bell housing question - 1 piece MT or 2 piece?
Post  xschop on Sun Jan 01, 2012 11:30 am
Get the 2-piece. Makes clutch diagnosis painless and initial pilot bearing-to-shaft placement super easy.
Happy New Year.
Post  rooster on Mon Jan 02, 2012 8:36 am
Thanks xschop, I'll get the two piece.
By the way, what brakes are you running these days? It seems like I've seen a lot of threads from you with different set ups. What did you finally settle on?
Happy New Year to you too.
Andrew
rooster
Post  xschop on Mon Jan 02, 2012 9:22 am
Lexus Monoblocks/Boxster-S rotors up front....RX7 4-pots/951 rotors rear. 5/8" Wilwood Master on front circuit and 1" Wilwood master on rear. I have tested the Wilwood Superlite/ Cayenne 330 rotors up front and designed a kit for them. They perform incredibly well. When spring comes I will design the adapters to put Wilwood Radial Dynapro's on the rear with 951 rotors. The Z06 caliper/Cayenne 350mm rotor may be reserved for a track build. Very Happy
I still have a couple sets of these left with centering rings....
Post  948inVA on Tue Jan 10, 2012 4:53 pm
Where are you guys finding the 2-piece bell housings?
948inVA
Post  xschop on Tue Jan 10, 2012 5:49 pm
Junk yard, CL, or parts house....
Post  948inVA on Tue Jan 10, 2012 6:21 pm
Thanks.. I was looking on ebay but couldnt' find anything.
948inVA
Post  stuart f. wright on Tue Jan 10, 2012 6:22 pm
i found mine on corvette forum
stuart f. wright
Post  rooster on Tue Jan 10, 2012 10:06 pm
Turns out there is a C3/C4/C5 Corvette only bone yard in the St. Louis area that had a two piece unit. I drove over and picked it up for $100. I think there is another one at Dino's Corvette Salvage:
Good luck.
rooster
