Front control arm bushings
I broke a vise putting in my front control arm bushings on an 87 turbo with aluminum control arms. So, a friend of mine is using a press to push them in. He got one in at 2 tons of force and the next one got stuck at the same place I did about half way in and the press is up to 10 tons of force. Anyone know what the normal force is or if it is safe to go higher?
Re: Front control arm bushings
Add a little heat on the control arm and put the bushings in the freezer overnight? That's what i would do...
Thanks, I did freeze the one I did for a couple of hours. I will suggest it to them. They are just spooked by the tonnage. One side went in at 2 tons and the other is stuck at 10 tons.
