Upgrading Suspension Bushings
+3
skywalker01
99sierra4x4
7 posters
Hey Guys,
I am just about ready to upgrade the front Suspension Bushings and probably the back as well.
But I would like to tackle the fronts first. I do not want to go crazy and get the spherical stuff, I was leaning towards a polyurethane kit from power flex, or on 944online they have a complete upgrade set, and elephant racing has "sport" rubber.
Does anyone have any suggestions? I will be upgrading the shocks / springs as well.
Andy
Andy
99sierra4x4- Posts : 121
Re: Upgrading Suspension Bushings
99sierra4x4 wrote:Hey Guys,
Andy
I just went through an upgrade of my suspension, using the polycarbonate and delrin bushings from Paragon Products and I hardly have any body roll. Increased the size of my torsion bar too. Seeing significant improvement in the car on the autocross courses - actually going to step up to R-Comps to do battle with the Factory Five crowd this season. By the way, if you're planning on keeping your rear swaybar, I would also suggest replacing the droplinks on the swaybar to solid ones. Good luck!
skywalker01- Posts : 477
Track or street car?
I am going to be doing both possibly, mostly autocross events.
just go nuts and do it all with the good stuff. You can do it all for under a grand. I did all of the solid bushings from elephant, and all of the delrin sway bar and power steering rack bushings from racers edge. If you don't do it now, you will wish you had later, and then you have to take it all apart to redo it. Do the front this year and the back next year if you have to.
zeusrotty- Posts : 444
Thats what I was thinking, I really don't want to do anything twice....
I used the Elephant racing bushing in the rear for my torsion bar delete. So far so good...
If you do the front, you will need to do the back as well. I blew out 3 rear wheel bearings and a stub axle in one season due to bad rear bushings.
Interesting. I guess I will have to do everything all at once.
I havent used poly bushing in my 944 but I have used them in my other cars. Yes they do tighten everything up and in general make everything feel more put together. However, do not skimp on the grease. If you dont use enough they will squeak like crazy.
bordin34- Posts : 10
So far I got the stuff for the front, delrin kit from Racers Edge for the front of the A-arm and Polyurethane from Powerflex for the back of the A-arm. Looks good so far. Next is taking apart the rear and getting the upgrades going for that.
Andy
Andy
Don't forget the strut hats/bearings. The early tophats can be modded with polyurethane and then used on early, as well as late cars, because the poly will take the extra angle when used on a late offset.
Someone with access to an injection mold could copy the rubber inserts in poly. I cut mine on lathe from poly stock.
» Front control arm bushings
» upgrading to 33 spline 930 chromoly stub shafts
» WTB: Trailing Arm Bushings
Today at 6:58 am by Rob44
Today at 12:47 am by sharkey
