Okay made my choice now need help
+3
stu wright
IFeelOld
7 posters
Page 1 of 2
Page 1 of 2 • 1, 2
i'm going to be rebuilding my 1979 4 bolt main 010 350 chevy block to put into my porsche 944 to turn into a 948
i this engine had engine knock got it for 100 dollars with everything on it
ill post pictures of it and my car up later on this coming week i need help on what to do and buy to get this all running right and into the porsche
for now ill be rebuilding the motor
i got stamp code of 3970010 and 010
i was wondering what i should do to repair the engine knock i never heard it run so i dont know how bad it was
also would it be better to just do a full rebuild kit and witch one is best ?
there was talk about a tubelar front end crossmember that has motor mount brackets on it does anyone know where i could get ether the specs to re-create it or where to buy it ?
also what year corvette bellhousing should i get from a junk yard and what else should i get from a junkyard for that matter ?
i know my spelling isnt that good but please help first i was going a lt1 route but i like the sbc alot more and i got it alot cheaper
thank you
thank you
IFeelOld- Posts : 37
Re: Okay made my choice now need help
I sell the tubular cross member for the motor mount replacement setup.
No, you can't have the spec so you can recreate it
It took a ton of R&D work to get it right. If you want to copy it you'll have to buy it first........
PM me for a price.
I would rebuild the complete motor before you install it no matter how slight the knock is/was. Make it a stroker 383 that's what I did.
PM me for a price.
i would love to buy one i would't want to steal it it was kinda a joke he he
and yeah whats the best way to stroke the motor to 383 ?
can i just buy a 400 crank with new H rods and pistens ?
this is the car and motor i am rebuild its a 350 4 bolt main
looking for a rebuild kit and wanted to know if i have to bore it over ? the cylinder walls seem okay but i am not sure also the code on the block is 3970010 and 010 you can see it kinda but there is alot of grease on it as anyone can see
i plan on getting it cleaned and going to do a rebuild kit myself any know a good company that offers a rebuild kit for this motor ?
is this a good motor for the sbc 944 swap ?
performance automotive warehouse is in california and would be a good source for your rebuild kit parts.if yo have a local machine shop they can help you with hot tanking the block and measuring your cylinder wall bore along with magnufluxing the block to check for cracks. the cylinder heads also need to be checked also.depending on the mileage of the engine and wear affects the amount of work to be done.the crankshaft also needs to be checked.the condition of the main bearings is a good place to start on the cranks condition.is there any copper showing on them or any scracth marks.performance automotive warehouse should sell whole rotating assemblies containing crank rods and pistons.you just need to see whats in your budget and weigh your options to see how much you can afford to spend.the machine shop you have localy also should have a inventory of good parts that you need to rebuild your motor.the better the rebuild and the right parts to make it all work and last is the most important.do it right the first time .
stu wright- Posts : 312
thank you i checked there rebuild kits the one i like from them is about 170 ish
also i been talking to a machine shop near me but his hot tank is broken for atlest 2 weeks something about someone blew a motor in it or something im not sure i got to wait
also should i keep the stock heads just clean them up or maybe port them ? or just buy newer heads for it
again i dont want much horse power just about 280-350 ish ? and running on 91 pump gas
also is there a way to make this smog legal in california V8 carb setup ?
the smog legal calif thing i dont know much about but there is some ca members on that can help you with that part.as for heads that depends on your budget.vortecs make really good flow.or you can rebuild your heads
well for the heads i know how to port ( ive done afew honda's and nissan heads ) but they really where all 4 cylinder engines and i got a cardide but not 100% sure if i should
how much do vortec heads normally run ?
you can find them for 600 a pair some places .sometimes you can get on ebay and find them cheaper.im running dart heads on mine but they r expensive.300 to 350 horse you should be able to get out of some 882 heads.thats a stock gm casting.if your budjet can afford is where you need to look.you can make some decent power out of a stock 350.944s only weigh 2700 lbs .power to weight ratio is greatly increased with a stock 350.my first engine in mine was pretty mild and it was pretty quick
thanks i think ill just port these heads and buy that rebuild kit maybe do roller rockers ?
i know i wont need it really but i like the durability of the rollers im sure they will help anyway
there will be a clearace issue with roller rockers as they require tall valve covers which will interfere with master cylinder. you will have to delete the stock vacum brake booster for the stock valve covers to clear.and you will need to get a plate or make one to mount the master cylinder to the firewall .you will also need to decide about whether you want power steering or not.its best to know some of those issues before you start
i was going to go power steering only no a/c or anything water pump will run on a eletric motor and i need to find what rad to get also for the brake master cylinder i dont know what to get really i have edelbrock valve covers that seem to be taller than stock ones i would need to get the motor where i want it and know how much clearance i have before i pick witch mc i will use i am pretty sure the normal kit from 944v8s will work fine though
with tall valve covers the mc might need moved over a little.i went a different route on my mc.with manuel brakes the dual mc is probaly a good choice but im using a single mc mounted in my floorboard.i got a little extreme with mine.i used to have mc on firewall but when i added tall valve covers i had a clearace issue.i have a solid roller cam so periodic adjustment is required.it makes it easier to remove valve covers with mc out of my way.
sure it a 350? i looked up codes and found it was also 302. look at my conversion. i got a 307 and now switchin out for a bigger and faster motor. i am running an electric water pump, 35 gallons a min. got a single groove pulley to put the alt. on and have my stock rad., and twin electric fans.
modenas- Posts : 285
positive its a chevy silverado 1979 motor and but the same code was in a z28 yes but its from a chevy silverado
okay was just wondering it says i can use a stock sbc bellhousing for a sbc and lt1 do i need to get a adapter plate to connect to the torq tube ? can i machine this peice myself and where can i get the specs for the old sbc bellhousing adapter plate
i got some stuff for sell you might need. but yes you need a plate adapter from the 944 tt to the c5 bellhousing
pm me what might you have i am planing to by the tube cross member from the admin here use that for the sbc mounts and all so i can keep the stock oil pan
but i do still need alot of stuff
took my motor to clay smith cam's to get it tanked and checked out
might have it back in less than a week
cant wait
cant wait
Unless you have a 1979 944 that conversion will NEVER pass smog. To be legal it must be the same year or newer block and emissions equipment. Also you cannot use a truck motor in a car. Time to find a Nevada address and register that pig there.
Dawgz83948- Posts : 603
i found a old friend from high school that was alittle older than me that now owns a smog shop ... i pay him 125 and i get it passed
but yeah i do wish i could have it legally pass smog
Save $2500 for when you get pulled over and the COP see's no BAR label. Good luck with that. I've already been pulled over 4 times, and the cop had started writing a ticket until I showed him my BAR label, once was in your neck of the woods.
Or he could be a real prick and write you up for modified for racing and have your car crushed. You really need to know the law before you do things....
i dont really plan to drive it that much if its that much of a hassle ill just keep it as a track car for mazda luguna and then use my 750 gsxr for a dd
Sweet. Just remember.
Telling you about being pulled over in L.A. makes me chuckle because of the id10t cop that pulled me over. He comes to my window and tells me that he called a tow truck and that he owned one of these cars before any that I've modified mine so it's illegal to drive on the road. I showed him my BAR label and he called it off. He asked me at the end what would I have done (cause I was getting pissed after he tells me he's going to tow my car) if I didn't have the bar label. I looked at him with a serious face and told him "I've reached 183 in this car with more to go, I have a full tank of gas and you guys would have one hell of a race to Mexico" Still makes me laugh, the look on his face as we said goodbye.
Page 1 of 2 • 1, 2
Page 1 of 2
