block choice limitations
What small blocks can't be used. I was wanting to use a 4 bolt main 70s truck block...
Will I have any issues with that choice?
sam_porsche- Posts : 9
Re: block choice limitations
Beyond using a carburetor and the inherent hood clearance by doing so, no. All SBCs will work.
How about a stroker motor, are there clearance issues with the modified pan, is anyone running one?
tooms351- Posts : 50
I just picked up a stroker motor to replace mine. I'll soon find out if my old oil pan will fit... I'll let you know what happens. I pick up the new motor this Saturday.
Thanks, and good luck! I need some more HP/TQ to keep up with those C6s on the straights, I've got about 420 now and think another 80HP should keep me in the game!
Just a simple update...
I picked up a good 4 bolt block. Bored it 60 over with some nice Keith black dome pistons. Snagged a good Wieland 8004 intake. Steadily making progress.
Just got it cleaned up.
I know these photos don't mean much but I wanted to share.
Sam
Sam
