Xschop's 5.3 LM7 build
+46
piperporsche180944
jwink25
beario
shokwave30
Powerman951
Constantine
skywalker01
stu wright
suboptimalfit
odurandina
mvallee
Bluemach1
CyCloNe!
Marky522
LEEEZARD7
Tehone
airheadhubs
HHPtoy
map21
cjbcpa
Luke714
adam7e
Wild Bill
modenas
kelleysj
968gene
ffmedic
Tetzuoe
50 posters
Page 17 of 17
Page 17 of 17 • 1 ... 10 ... 15, 16, 17
Re: Xschop's 5.3 LM7 build
it has been done.
LEEEZARD7- Posts : 148
vette trans
It takes a little bit of work to install the vette trans. I am in the process of doing so, but still using the porsche running gear, where Admin is using the vette suspension complete in the rear. A little cut here and cut there, but it will be worth the effort in the end for the low rpms at hwy speeds. It also allows a host of easy to change gear choices.My trans is a 342 but will change to the 271 for hwy cruising.
kevin924kevin- Posts : 927
In looking at your thread it looks like alot more than a little cut here or there!
Lots of fabrication work, it'll give a good result, but it's far past my abilities and I don't feel the gains are worth it for me to pay someone to do it for me.
Fact: The Vette 6-speed turns 1475 RPM doing 70mph WITH 3.43 differential. This is why I'm starting the 926-LS build soon. Stronger trans better gears for the V8 and 930 axles to boot.
The 944-Vette trans takes dedication and time. I like what Kevin is doing and keeping the 944 suspension.
That Vette 6th is tall!
My 0.68 5th from a mid-80's Audi 5000 diesel gets me about 2200 at 70mph. iirc, I think I was at 2900-3000 with the original Turbo 5th.
acorad- Posts : 697
vette trans
Just imagine how low the rpms will drop with the 271 ratio. xschop sorry this should not be clouding up your thread.
whomever is purchasing robs car is a lucky guy. nice ride.
GOT A RIDE IN THE 948... NICE!!! SHOWED UP A OLD GUY IN A VETTE LOL.
I fly in next weekend for the car, super excited. As I make my own modifications to the 948 I will keep updating this thread, I have a few ideas alreadyLEEEZARD7 wrote:whomever is purchasing robs car is a lucky guy. nice ride.
watsondk- Posts : 33
have fun with it watson!
xschop wrote:Sorry, As of July 3rd, still no harness, VSS kit, nor Oil Filter Relocation kit from Greg....
My SSP harness is installed and done..... and I've ordered a filter relocation kit from Ebay....after that I can drive it to the exhaust shop..... I will build my own Billet VSS kit later......
Hey Billy, do you know if this car ever had a factory alarm?
I also disconnected the Green/blk hot wire directly at the rear fuel pump with a long wire lead to read continuity of the circuit....confirmed that it goes and connects to DRIVER'S SIDE of FUSE #34....So as I suspected, you either remove fuse #34 and use a single spade to jump it OR the Green/Blk wire at the 14-pin connector ties in under the fuse panel Very Happy (which is what I did)...
For the new PCM relay, I simply added a jumper connector (ON DRIVERS'S SIDE).... Wink
The fans were easy. Just tied in to the large RED/blk and Black/red wires in the loom right next to the driver's side strut tower.....
.................No More Porsche DME/Fuel pump relay or Fan relays........Happy Independence Day!
the 30 86 87 85 relays are fairly generic and can be purchased as vw rabbit fog light relays very inexpensively. my .02
hey rob, hows it going? mike in piedmont here. give me a shout.
964ruf- Posts : 22
Been a while since I last posted, my good friend just wrote an article on my 948, check it out and see if we can get one of our cars to the Jalopnik front page!
Dinsdale and I will make front page with the Twins.
Brake Conversion
XSCHOP. what did you end up doing on your brake conversion for front and back? THanks
TampaPete- Posts : 5
I made some adapters to put RX7 calipers on the rear. They work great with factory 951 rear rotors, you just have to trim a small area of the caliper to fit.
I have a set of those adapters if you're interested I'll let go for $115 shipped.
Brake Adapters
That sound good. Let me know how I can get you the money and I pay, send a check or whatever for them. I will also send you my shipping information. THanks
My PayPal is [You must be registered and logged in to see this link.]
Just search the thread here.
Rob,
If possible could you PM me with your new contact information? (211lotus) My project is just getting started after I purchased your adapter and motor mounts two years ago. I have a question regarding the size of bolts to used to attach the bellhousing to the adapter and the adapter to the torque tube. I tried your e-mail but it wouldn't go through.
Brian H.
Brian H.
211lotus- Posts : 2
Brakes
Please PM me your mailing address and I will send you a check. Will that work?
Hey Pete, sent you a PM. That'll work. Take care,Rob
If you need anything else, my email is
On my C5 adapter plate, you need 7/16-14 tpi Allen studs that are 1.5" long.
The BH bolts IIRC take M10x 1.5 x 40mm long
Brakes
Can you PM me your address again so that I can send you a check for the RX7 rear brake caliper brackets. Thanks
Page 17 of 17
