Throwout bearing
Throwout bearing
I'm installing the I5 turbo motor from an Audi into my 44 and am researching the hydraulic throwout bearing. Which one are you guys using? I figure that if it isn't a direct fit that it should be a good starting point. Thanks.
powaw- Posts : 8
Re: Throwout bearing
u will probaly have to use your exsiting porsche setup as we use chevrolet motors and bellhousings with an adapter plate to mount to tourqe tube.
stu wright- Posts : 312
The actual mounting is done. I use the 931 bellhousing and 2.8 liter spacer plate. The flywheel is a fidanza unit with a southbend pplate and custom disk. I figured that we would use the same or similar hydraulic throwout bearing.
powaw- Posts : 8
» So....I think i need a throwout bearing
» Throwout bearing over-extended?
» Video of Throwout Action
