Throwout bearing over-extended?
I was testing my clutch hydraulics after bleeding the system today, the clutch is not installed yet. When I pumped the pedal the fluid started leaking out the end of the throwout bearing. I guess I wasn't thinking, but I'm assuming it overextended resulting in the leak? Is there a procedure for re-seating it?
948inVA- Posts : 224
Re: Throwout bearing over-extended?
supes6 wrote:I was testing my clutch hydraulics after bleeding the system today, the clutch is not installed yet. When I pumped the pedal the fluid started leaking out the end of the throwout bearing. I guess I wasn't thinking, but I'm assuming it overextended resulting in the leak? Is there a procedure for re-seating it?
I just use the palm of my hand and press the bearing down firmly. It will "pop" into place. Make sure to oopen the bleeder so it will go down easily.
And heres a thread for the slave/TO bearing taken apart and messed with.
Great, thanks for the help!
» Need Pricing Help on throwout slave
» extended crank flange engines OK??
Today at 12:47 am by sharkey
