So....I think i need a throwout bearing
Had a recent issue crop up...blew an axle up and i think the stress harmed my throwout bearing (there is a very interesting...read scary...sound coming from the bellhousing/clutch area). The clutch still works flawlessly, which leads me to believe that the sound (which changes when i depress and release the clutch) is indeed from the throwout bearing.
My bellhousing/clutch system is all from renegade (picked it up for cheap on ebay before the big hubbub over on PHB) so i have no idea where to find a replacement without having to go through renegade. I was hoping to not have to replace everything in the system, since it seemed to work fine before i blew it up...Any ideas guys?
v8944- Posts : 211
Re: So....I think i need a throwout bearing
that is ussaly a sign of a bad throwout bearing.you just been having a string of bad luck latley first distributer now this.somtimes you have to go backwards to go forward thats how my 944 been going here latly hope i can get mine going soon without anymore glitches.sounds like youl b pulling your motor to replace that .
stu wright- Posts : 312
turns out my luck might have switched on me. I took a real hard listen and the noise is coming from the transmission i put in the car recently. This new trans is an early lsd model, so the little noise i was hearing (which sounded different inside of the car than outside) is just a little bit of gear noise, probably from the limited slip clutches or something like that, only when the car is in neutral and the clutch is depressed.
finally i catch a break (knock on wood...)
phew
phew
v8944- Posts : 211
