Today at 8:58 am by JSP
» Tpc LS adapter plate
» Headers, headers, HEADERS!
Throwout bearing
Throwout bearing
Post  powaw on Sun Feb 21, 2010 4:40 pm
I'm installing the I5 turbo motor from an Audi into my 44 and am researching the hydraulic throwout bearing. Which one are you guys using? I figure that if it isn't a direct fit that it should be a good starting point. Thanks.
powaw
Re: Throwout bearing
Post  stuart f. wright on Sun Feb 21, 2010 5:05 pm
u will probaly have to use your exsiting porsche setup as we use chevrolet motors and bellhousings with an adapter plate to mount to tourqe tube.
stuart f. wright
Post  powaw on Sun Feb 21, 2010 7:51 pm
The actual mounting is done. I use the 931 bellhousing and 2.8 liter spacer plate. The flywheel is a fidanza unit with a southbend pplate and custom disk. I figured that we would use the same or similar hydraulic throwout bearing.
powaw
Post  Admin on Sun Feb 21, 2010 8:10 pm
Look at the RAM brand TOB they are shim adjustable and could easily be adapted.
Post  powaw on Sun Feb 21, 2010 8:14 pm
Thanks for the tip, I'll check them out.
powaw
