Adding Purge Solenoid Wiring to Standalone Harness
Hi guys, I have very limited wiring experience and was hoping for some specific instruction on how to add my EVAP purge solenoid wiring to my aftermarket standalone harness and stock PCM.
I am mostly finished my ls swap and have decided to add in the stock GM EVAP system to properly deal with the fuel tank vapors. So far I've pulled the stock connector and wiring from my stock harness so that I can add it in to my aftermarket harness. I know that the green/white wire needs to be added to pin #34 of the red PCM connector, but my main question is what do I do with the pink wire? Where and (possibly more importantly) HOW, do I add this to my aftermarket harness?
I've attached pictures of both my EVAP wiring and a picture of the fuse block of my aftermarket harness. I assume I need to add the pink wire to one of these fuses somehow to get ignition signal? I really don't know what I'm doing. Some help would be very much appreciated!
Bare with me... I can't figure out how to orient photos properly with the Servimg function...
ndog52- Posts : 12
