low cost and available bellhousing...maybe
+2
murrayg
6 posters
Hi everyone,
I'm starting another LS1/6 into a 89 944. I'm collecting parts and everything is coming together except.... the C5 Corvette bellhousing - p/n12554980. This is the manual 2 piece bellhousing that I've used in the past, and works great. But they are getting very hard to find, and expensive. A QuickTime one at near $800 and 22lbs is not an option.
However, the automatic bellhousing (p/n12551118) is available and cheap! There are literally dozens on ebay for under $100.
Let's start a discussion and collect thoughts on using the auto bellhousing for a conversion. The release bearing mounts to the TT or in our case, the adaptor, so that shouldn't be a show stopper. I understand an 11" flywheel /clutch won't work, but a 10 1/2 will, what GM applications had 10.5" clutches?? I'm willing to put the work in here, if these auto bellhousings will work for us. Thoughts??
Gord.
Gord.
murrayg- Posts : 105
Re: low cost and available bellhousing...maybe
i spent a bit of time looking through rock auto and cant come up with a factory LS application that uses a 10.5" clutch. f-body, gto/g8 and corvette all use 11 7/16", ctsv uses 11.5", and trucks use a 12".
there are aftermarket performance 10.5" clutch combinations out there for the ls, however going this route will likely cost far more than the 2 piece bellhousing and using an oe pressure plate/flywheel.
I am also just starting on a conversion (1991 s2 > LQ4) and had the same questions, so thank you. It appears that there is a spacer required between the block and bellhousing in order to use an 11" clutch with the 1 piece bellhousing, but I can't find any reference as to the thickness (seem to remember seeing .500" but am not sure). This brings up another problem, which is that any spacer there will move the engine forward in the car and will add to the clearance problems between the throttle body and hood as well as change the engine mount location.
Is there anyone out there that has used the 1 piece bellhousing that can shed some light on the proper parts to use and how this will effect everything else?
Chris
Chris
Fairmont50- Posts : 8
murrayg likes this post
The 1 piece bell housing has been being used for some time.
TPC (i am the owner) has a complete kit.
To use the one piece you need:
* Modify the bell housing for the hydraulic lines
* use a 1/4" Spacer
* Extra long dowel pins (good idea)
* Use TPC's modified Adapter Plate
The 1 piece works and has been tested using the stock TPC Clutch Disc, GM flywheel and pressure plate,as well as SPEC kits.
Let me know if you have any more questions.
* use a 1/4" Spacer
Fairmont50 likes this post
Fairmont50 wrote:I am also just starting on a conversion (1991 s2 > LQ4) and had the same questions, so thank you. It appears that there is a spacer required between the block and bellhousing in order to use an 11" clutch with the 1 piece bellhousing, but I can't find any reference as to the thickness (seem to remember seeing .500" but am not sure). This brings up another problem, which is that any spacer there will move the engine forward in the car and will add to the clearance problems between the throttle body and hood as well as change the engine mount location.
Chris
The 1 piece bellhousing and the quicktime bell housing are currently the only ones that are available now. The original 2 piece bellhousings are next to impossible to find. I have built several 944's and am currently building another one using the 1 piece bellhousing that Kent sells. It is modified for the 944 swap. There are several things that have to be done, as in machining, to the BH to make it work. Kent does all of these for his kit. He sells it with a 1/4" spacer that goes between the block and bellhousing. And also has the correct torque tube adapter plate for this BH. The spacer does not change where the engine sits. This is always dictated by the motor mounts. Nothing changes in the engine or torque tube locations.
I have a one piece if anyone is interested.
$50.00 + shipping
$50.00 + shipping
T951- Posts : 10
