C5 Corvette wheels on a 944
+6
RobotMachines
Tetzuoe
alienwerke
10 posters
Page 1 of 2
Page 1 of 2 • 1, 2
I was going this route before finding Turbo Twist II wheels.
I will still make adapters for the wheel swap if you guys figure the dims that the adapters need.
I have seen adapters for 5x130 to 5x4.75" pattern, but have never seen any that have a hub centric ring on the Chevy side of the adapter. I will only put my name on something that is built solid and correctly with hub centric rings on both sides. Gt1Scca says he knows someone that put them on a 928 with great results, so why not the 944?
Come on let's build some sh$t....
I am privy to these ones but thicker adapters can be made for the later 5 spokes that have deeper backspacing.....
Reason for edit.....PORH
Re: C5 Corvette wheels on a 944
hows about you start taking the dimensons off a a set of wheel spacers. i have a pair i could lend u for the purpose dimensions.
alienwerke- Posts : 21
[ ^ These are C - H - E - A - P used ...^ ]
C5 / C6 Wheels
[Sizes and backspacing...]
C5 / C6 Wheels
Working on that as we speak...( I have a set of front adapters here...)hows about you start taking the dimensions off a a set of wheel spacers. i have a pair...
gt1scca- Posts : 795
Low Cost solution
Booyah.... I could machine these down to an inch, but not sure if the inner diameter had enough material to leave 1/4" tall hubcentric ring for the Vette Wheel.....But would work and you can't beat the price!
I need a copy of that CF toilet
................RRS
................RRS
Oh those are sweeeeet.
Can you do plastic engraving XS??? Maybe put the P-crest on the wheel caps???
Or, put PORH on the rear caps.
I know you have heard of the RS America cars...
How about an "RRS" wheel?
uh, holy crap... those are pretty if they were truly rectangular spokes... like those volvo R wheels, id be in love. (I have a soft spot for rectangles.)
Tetzuoe- Posts : 178
Engrave
RRS.......LMAO!
on a wheel no doubt, Fekkin genious.
I can engrave anything with a couple different fonts. If a true basic forum kit comes about which I can see is not far off, I will engrave 944 Hybrids on any billet I do for this Forum's support. If Renegade slanders me one more time, then these next batch of C5 adapter plates will become "creative"....
PORH
RRS
POPP
PORH
RRS
POPP
back on track
If the 944-C5 wheel spacers can be 1" thick, I think some 1-offs are definitely a go. I have found some billet (T-6061) on the cheep at the size I would need
Those would definitely work. The fronts would have a couple of mm's more offset, No problem.
A double-sided hubcentric adapter set would be icing.
Here ya go Tetz...same offset, C6 wheel.Tetzuoe wrote:uh, holy crap... those are pretty if they were truly rectangular spokes... like those volvo R wheels, id be in love. (I have a soft spot for rectangles.)
CHROME IS FORBIDDEN!
otherwise those are pretty
you were holding out on me! these were in your gallery all along
this is more like the style I was talking about, man, shoulda found some of those.
5 X 130mm to 5 X 4.75" adapters
I copied this post from the LS430 thread...
Here's a set (of adapters) that will work...
(not hub-concentric though...)
Part # LM5/130/475
lugmanusa.com
Also states they will fab custom orders...hub-concentric should be possible.
Part # LM5/130/475
Thickness 1.25 inches (31.75mm)
Studs Installed 12mm x 1.50 Thread Pitch
Lugs Included 12mm x 1.50 Open End Bulge
Center Bore Diameter 2.878 inches (73.1mm)
Special Orders can be built to include optional
stud sizes and adapter thicknesses from 0.79
inches (20mm) thru 2.0 inches (50.8mm)
lugmanusa.com
Hmm... but how much do these wheels weigh? I have 16x9 rear aftermarket (made in Japan) cast Fuchs on my 944 and they are heavy; something like 24-25...lbs (the ones in my avatar are the 16x7 OEMs). I mention this because I could really feel the difference (unsprung bounce) from my OEM 16x7 forged Fuchs (something like 18lbs) I used to have on there. The fakes do look too good to take off though.
RobotMachines- Posts : 165
Corvette Wheels Standard Sizes:
Cast Aluminum
Front: 17 x 8.5 Tire size: P245/45ZR-17
Rear: 18 x 9.5 Tire size: P275/40ZR-18
Bolt pattern 5x4.75" (same as 5x120.65mm)
Front offset=58mm, Rear offset=65mm
Z06:
Forged Aluminum
Front: 17 x 9.5 Tire size: P265/40ZR-17
Rear: 18 x 10.5 Tire size: P295/35ZR-18
C5 Corvette Wheel Hard Core Data
C5 Corvette Wheels Weight by brand and type
19.2 lbs, front; 21.4 lbs, rear - 97-99 OEM wagon
22 lbs, front; 29 lbs, rear - 97-99 OEM wagon
17 lbs, front; 19.5 lbs rear - 97-00 OEM magnesium
17.5 lbs, front; 19.5 lbs, rear - 97-00 OEM magnesium
18.08 lbs, front; 20.06 rear - 00 OEM standard, thin spoke, high polish
17 lbs, front; 20 lbs, rear - 00 OEM standard, thin spoke, painted, no sensors or centercaps
16 lbs, front; 20 lbs, rear - 01 OEM standard high polish
19.6 lbs, front; 21.4 lbs, rear - 01 Z06 forged
19.2 lbs, front; 21 lbs, rear - 02-04 Z06 cast/spun
24 lbs, 18x10.5 - 00+ repro high polish
28 lbs, front; 32 lbs, rear - Z06 chrome repro
23 lbs, front; 26 lbs, rear - Z06 chrome repro
23.5 lbs, front; 24.5 lbs, rear - Z06 Motorsports, polished
20 lbs, 17x8.5, 58mm offset, front; 23 lbs, 18x9.5, 65mm offset, rear
22 lbs, 18x10.5, 58mm offset, front - HRE 545 w/clear center
27 lbs, 18x12, 74mm offset, rear - HRE 545 w/clear center
24/25 lbs - Z07 wheel weight, front
28 lbs - Z07 wheel weight, rear
*Not extremely impressive, but lighter than the Fuchs...
Cast Aluminum
Z06:
Forged Aluminum
Aaaahhh... magnesium. Nice.
would it be possible to fit these on the back?
they come in a 9.5" for the front too
mmacias2- Posts : 6
That seems like real cheap for those replica wheels brand new. Do they give any weight information about them. I personaly think 11 rear and 9.5 front is a little big for the 944 but I guess I could settle if they fit right. Is the offeset such on the corvete wheels that there is room for adapters even on the late offset 944 or is this o nly possible on the early offset cars.
matthewb- Posts : 53
C5 wheels have an offset of 54 and 58mm, a difference of 31 / 35mm (on early 944 applications w/ a 23mm offset). The late 944 with a 53mm offset doesn't offer enough space for 1.25" adapters. The later C6 wheels, however, have as much as 64-68mm offset. C6 wheels may work on a late offset 944 with ~1.0" adapters.
Wheel width has a large affect on offset numbers doesn't it? Offset is distance that the hub face is offset from the center line of the wheel correct? So if you have 2 wheels with the same "offset" but one is 2 inches wider than the other won't the 2 inch wider wheel stick out an extra inch further than the thinner wheel? I thought I had all this offset stuff figured out, but maybe I don't. Seems like we need to be considering the width of the wheel along with that offset number to figure out if they will fit correctly.
Did you read this?
17 X 9 / 18 X 10 will fit.
Also, all width, offset, etc. was considered when working out the early C5 adapter details.
Yes I did read the other thread. I actually had the last post in the thread. It didn't talk about wheel offsets directly in the thread.
Looking at the diagram you posted, it looks like the corvette wheel will stick out further by about 3/4 of an inch. That is what I was talking about in the previous post.
Have adapters been made and these wheels put on a car yet?
Nope.
Lugmanusa.com sells the adapters, and I just haven't gotten to the wheels yet. From the research I have done, they should fit...BUT, theory and application are two different animals. To be 100% certain, they should be mounted and verified. A 1.0" adapter may compensate for the 3/4" difference you foresee at the fender.
I mainly went to the trouble above just to determine if it was possible.
If I missed something, I'm sure I can work it out when I fit the C5 wheels.
Worse case, the hubs can be plug-welded and re-drilled, but I don't really think that will be necessary on the early offset.
Page 1 of 2 • 1, 2
Page 1 of 2
» Turbo Transaxle wanted
