ls2 automatic, what flywheel should I buy
Have my 06 gto ls2 automatic motor, need to buy the appropriate flywheel and clutch setup, can I just use the corvette manual flywheel / bellhousing for my set up?
This motor will be going into my 968 cab.
I have the billet torque tube adaptor for the bellhousing too.
Mike
IE: anyone in Orlando that has done a swap?
Mike
mdan1- Posts : 8
Re: ls2 automatic, what flywheel should I buy
Texas Performance Concepts has most of what you need. Also there's a one piece bellhousing from QuickTime Performance but they cost a bit more. , Spec has a decent selection but at a price....
alex456gt- Posts : 11
flywheel from auto to manual
do you use a stock manual c6 bellhousing or the two piece c5 version?
I can get a one piece c6 manual bellhousing pretty cheap locally.
mdan1- Posts : 8
Today at 4:44 pm by JW1970
Today at 12:39 pm by Nath1142
