Automatic harness/pcm OK?
Will a wiring harness and/or pcm from an automatic work for our purposes? Engine is a 94 LT1 from a Corvette.
Re: Automatic harness/pcm OK?
Yes, just cut out everything for the transmission but the VSS. Also when you take your car in for the BAR inspection, you'll need to program the computer with a VIN from a manual car.
Dawgz83948- Posts : 603
If you find a Vette Manual VIN thats a California car PM me the VIN. They don't report it, but they do check it with GM to verify its a Manual car.
OK, will do. Have quite a bit left to do before I worry about getting past CARB.
