4.8 Swap questions
4.8 Swap questions
So I have that 944 N/A transmission and I am about to install it into my 924. Currently the 924 has a mix mash of parts, but has a 944 suspension as well. I know ideally the 951 transmission should be used, but I really would like to use the 944 N/A. I don't mid going with a lower HP engine like a 4.8 GM. From what i have found online the 944 N/A works well until you hit the 300-320hp mark and the stock 4.8 is about 280, so what's from stopping me?
I'm not a GM guy, I could wrench on the engines all day long, but i don't know what intake to use bell housing adapters etc... Would the C6 bell housing fit on the 4.8 from Texas Performance Concepts?
What are the interchangeable parts when it comes to GM engines?
Ideally,... in my 924, I'd like to run a 4.8ltr to a 944 N/A transmission.
ThomasJoseph315- Posts : 17
Re: 4.8 Swap questions
Thomas,
welcome to the madness.
I am also a novice when it comes to wrenching on anything. this forum has provided me with a lot of info and made me finally just say ...do it....
I'm in the process of swapping mine and slowly working out the kinks.
i got my kit from TPC, Kent has been a great help and will give you a lot off advice on which route would best suit your build.
I've posted on here https://944hybrids.forumotion.com/t3520-86-porsche-944t-ls1-swap-begins.
sorry if I didn't answer your question if an NA trans would work. I don't see why it shouldn't especially if you're keeping the power down. But there is always that temptation on putting the pedal down....sooner or later you may need to source a better transmission though.
smkn951- Posts : 60
I just made a deal to purchase a 951 Transmission.... screw it,.. go big or go home...
while you're at it...bigger engine....ThomasJoseph315 wrote:I just made a deal to purchase a 951 Transmission.... screw it,.. go big or go home...
well sooner or later you're gonna have to upgrade might as well do it from the beginning right..
good luck with the build and post some build pics and videos.
smkn951- Posts : 60
ThomasJoseph315 likes this post
Today at 9:47 pm by SpeedRacer11
Today at 4:44 pm by JW1970
Today at 12:39 pm by Nath1142
