» alignment specs
Today at 12:53 am by sharkey
Yesterday at 9:46 am by JSP
» Transaxle rebuild
» Tpc LS adapter plate
LT Swap Questions
LT Swap Questions
Post  MisterK on Thu Mar 13, 2014 12:34 pm
Well it's been about a year's work off and on so far but I finally left The Jack Stand Club of America and got my engine in the car and the car on the ground. The engine is from a 93 Z28 and the car is an 85.5. Now that I got the engine in I'm finally ready to start thinking about all of the other parts of the swap.
Namely, I'm looking for information about running an Astrovan Hydroboost unit with the LT power steering pump and the Porsche rack. I've already modified the booster to mount to the cereal bowl and I've got the Porsche master bolted up to the booster as well. My question is mainly regarding the plumbing. Has anyone ran this setup before?
Beyond the power steering my other question is about the cooling. Is the factory radiator really capable of cooling an LT1?
Additionally I'd like to say that I'm happy to finally be posting instead of lurking, and thanks in advance for any help.
MisterK
Re: LT Swap Questions
Post  bluehellfire666 on Thu Mar 13, 2014 7:53 pm
I've been running with the factory radiator for 5-ish years now with no issues...car runs exactly where it is supposed to temperature wise and I've never had a problem...a little extra cooling can't hurt though, and I've wanted to at least upgrade to a 944 turbo radiator for a while now, just haven't had the time or money haha!
In terms of power steering/brakes, no idea, don't have either...good luck!
Ethan
bluehellfire666
Post  MisterK on Fri Mar 21, 2014 8:55 am
Hmmmmmm. Interesting that the factory radiator works. Having the F-body radiator sitting next to the Porsche unit doesn't instill a lot of confidence.  Shocked
What did you do for your exhaust?
MisterK
Post  948 on Fri Mar 21, 2014 12:05 pm
The stock rad works for me in the PA/NJ climate, but only barely in the dead of summer when in traffic (I am only a few miles north from bluehellfire666). Summer in Orlando might be challenging. I have added a second radiator in the nose and now see no issues even with AC. You could also look at a thicker radiator, like the one from HMR. I had one but it cracked, and at $600 plus I was not looking to buy another. I now have the following:
951 Rad (Was an HMR 951 rad, but it failed)
Stock 951 6 blade fans and shroud.
Radiator is tilted forward ~ 7 degrees to allow room for fans
Secondary cooling system, in inter-cooler location
H valve
Universal AC core in original location
Stock Oil cooler
Exhaust is Sanderson shorties (I have custom mid-length headers to install), 2.5" downpipes in to Y-pipe then 3" all the way out. Magnaflow cat and Magnaflow muffler.
Post  bluehellfire666 on Thu Mar 27, 2014 12:13 am
MisterK wrote:Hmmmmmm. Interesting that the factory radiator works. Having the F-body radiator sitting next to the Porsche unit doesn't instill a lot of confidence.  Shocked
For my exhaust I took 2 patriot tight tuck shorty headers and cut the collectors off of them, welding 3 inch mandrel bent tubing to them to send them where I needed them to go. I took the two 3 inchers coming down from the headers and built a custom x pipe, running the dual 3's all the way out to two flowmaster 50 series delta flow mufflers.
bluehellfire666
Post  Fubar on Tue Mar 17, 2015 10:20 pm
I'm a noob on the site. I'm picking up an 87 S with a Renegade LT1 swap this weekend. It was the car that was on Craigs in Aberdeen MD about a month ago. It has a stock 94 Camaro LT1 engine. The swap was done by the  previous owner who was a machinist by trade. I want to plan on building the motor to around 400HP/400fp. I would like to talk to you about your swap and possibly stop over since we live fairly close to each other. Are you up for it?
Fubar
Post  bluehellfire666 on Thu Mar 19, 2015 12:02 pm
Absolutely man!! I saw that car on Craigslist and was tempted to pick up another one lol...I'm going LS next though.
Where are you located? I'm down in Bowie, just off of 301/50 (near the Baysox Stadium if you are familiar). Reaper (as I call my 948) is currently down for paint/body work and it needs new clutch hydraulics (which I have just haven't had enough time to put in LOL) But I'm planning on having her back up and running this Spring!!
Hit me up at Two40-393-3TwoTwo4 or [You must be registered and logged in to see this link.] if you want to get together some time man!
Ethan
bluehellfire666
Post  Fubar on Wed Mar 25, 2015 4:09 pm
I live in Leesburg. i drive to Baltimore to see my family quite a bit. I'll send you an email.
Barry
Fubar
