Sbc clutch
Re: Sbc clutch
You need one with the right spline pattern.
And need to match it to the power level.
I tried to screw around with a stock ford one "back in the day". You can get the pressure plate and disk form Renegade or Texas Performance now.
Re: Sbc clutch
i'm using ram clutch's 300 race series 10.5" disc 1"x 23 spline this will fit the drive shaft( the SBC DISC will not fit the drive shafts ). it's for mopor's
this mates up with the 10.5" SBC pressure Ram plates and flywheels.
i'm also using an adjustable Ram slave cylinder and a wilwood master with there peddles.
it handles the 400 HP and 400 FTLBS of torque of my motor.
962porsche- Posts : 135
» Selling off my stock clutch parts and RH clutch disc
» Automatic BH Adapter
» Two LSx swap questions, clutch replacement and working space
