Coolant / header tank cap
Hi
I'm having a problem with the water temeperature. It is fine when going along but when sitting at lights or in traffic it rises to half way up the gauge. It normally sits at about a quarter.
I have seen various information about overflow tank cap pressure and I wondered what evryone else is using. Please post and let me know? I have the standard 944 turbo header tank and a new cap. I believe the Corvette and the 944 use different pressure caps.
Engine is a '95 Corvette LT1 producing 285bhp.
Thanx
Q
Thanx
Q
Re: Coolant / header tank cap
That sounds normal. Mine does that. Normal operating temps should be around 190ish which is about half or a little above.
Hi Arthropraxis, thanks for the reply. However mine throws out the coolant as well and it can be litres!
There is no mayonnaise inside the oil filler cap, no water in the oil, no water emitted from the exhaust and no exhaust gases ion the coolant. I have a new thermostat, the water pump is rotating, the radiator has only done a few miles and i also have a new expansion tank cap.
But something is pressuring the coolant system to force the water out?
All comments welcome.
Thanx
Q
Thanx
Q
