» Headers, headers, HEADERS!
» Electric brakes
coolant hoses
coolant hoses
Post  quarterflash on Mon Jul 01, 2013 7:42 am
95 LT1 350 into 89 944 turbo. What hoses do you use to connect the radiator to the engine? I have the RH custom radiator.
Thanx
Q
quarterflash
http://porschevy.co.uk/
Re: coolant hoses
Post  Admin on Mon Jul 01, 2013 7:49 am
Ask RH, did they not give you any recommendations?
Re: coolant hoses
Post  quarterflash on Mon Jul 01, 2013 8:05 am
Hi
Thanks for quick reply. They did send some instructions to cover the whole installation but nothing specific about hoses. I did get the kit in 2004 though.
I thought that someone on the forum might have been through the process and would know which hoses fitted best.
I’ll contact them as you suggest.
Thanx
Q
quarterflash
Re: coolant hoses
Post  87-944S on Mon Jul 01, 2013 6:53 pm
Or do what most of us have done, including those of us with RH kits from way back, measure and head down to the local parts store and find a match. Very Happy
Hoses
Post  fliermike45 on Mon Jul 01, 2013 8:46 pm
Make some full scale sketches to take to the parts store.
This is also what I did, I have swapped three different cars and find it hard to actually find a perfect hose. I use two pieces per hose and join them with either a filler/bleed plug or a drain cock. Both from Jegs.
The drain cock was useful today as I had to change out my leaking plastic heater valve for a metal one.
Pictures tell the story.
UPPER HOSE WITH BLEED PORT
LOWER HOSE WITH DRAIN COCK
Last edited by fliermike45 on Mon Jul 01, 2013 8:49 pm; edited 1 time in total (Reason for editing : Added Jegs)
Re: coolant hoses
Post  quarterflash on Tue Jul 16, 2013 5:04 pm
many thanks for the information and pictures - they are really uaseful.
Q
quarterflash
Re: coolant hoses
