» Lighten clutch pedal feel?
January 2019
78910111213
14151617181920
21222324252627
28293031
LS Heater / Radiator / Reservoir Plumbing
Post  epsylon9mm on Wed May 30, 2012 7:44 am
I have a "H" vacuum valve to control the LS heater coolant loop and the 928 heater core loop. I am going to attempt to keep the stock 928 radiator for my build. The original 928 coolant return line turns into a hard pipe along the inner passenger fender that has a T in it for the the coolant reservoir to fill the system. Do I keep the coolant reservoir T'd into the LS heater return line or do I plumb this reservoir fill port to the top of the 928 radiator's vent port instead?
My LS oil pan requires a remote mount oil filter. Should I plumb the 928 radiator's oil cooler into this system or will this cause cooling issues?
epsylon9mm
Coolant res
Post  ynbad on Mon Jun 11, 2012 8:17 pm
I used the factory res and tie in on the heater hose the res fit in the factory position and was the easiest way without many modifications. As far as the oil cooler. I think the cooler is not nessasary and to hard to deal with.
ynbad
Re: LS Heater / Radiator / Reservoir Plumbing
Post  epsylon9mm on Tue Jun 12, 2012 7:53 am
ynbad wrote:I used the factory res and tie in on the heater hose the res fit in the factory position and was the easiest way without many modifications. As far as the oil cooler. I think the cooler is not nessasary and to hard to deal with.
I read somewhere recently, in my google searching, in a LS1 swap article that they plumbed the coolant reservoir into the water pump heater return. You also just confirmed this, thanks.
I really do not like the fact that the oil cooler is part of the radiator in the 928. There are known issues with the radiator failing and water or oil ending up in the wrong place. I gather the LS motors do not need one unless the intent is to track the car. It just feels like a waste since it is there. Another nice upgrade I can do later when I get the cash is to replace the radiator to make the oil cooler delete cleaner.
epsylon9mm
