transmission fluid survey
im trying to sort out what fluid to run in my freshly built AOR. currently running amsoil 75-90 gl-4 manual transmission/transaxle oil and im on the fence with it. i get a slight crunch on fast upshifts, it might just be the 250k km transaxle, might be the oil causing a bit of it, could be a heavy clutch disc causing it, its hard to tell.
so i was wondering what everyone here is running in their cars and your experiences with it.
Re: transmission fluid survey
Mobil1 75-90 LS.
Turbo trans with LSD and cooler but not AOR. Short shift kit at trans. Spec stage 2 clutch and lighten aluminum flywheel. Willwood clutch master, sized up from stock Porche ( 13/16 ? Can't remember ). Solid trans mount. Track car. A little balky 1st and reverse until warm. Trans runs 220-250 degrees depending on how aggressive I feel.
It did crunch for a couple of track weekends right after the build was complete. This seemed to be a drive train alignment issue. I loosened all bolts at each section and re-tightened. TT to bell housing first then trans to TT housing. That must have relaxed what ever was out of alignment which I suspect was the pilot and clutch end.
Jack
Jack
P911P951- Posts : 48
I have used Mobil 75/90 LS and recently switched to Redline 75/90 NS. Not enough difference to justify the price and I think it was a little smoother shifting with the Mobil. FWIW, the transaxle was rebuilt two years ago by Kevin Gross and he recommended the Mobil.
Arthropraxis wrote:I have used Mobil 75/90 LS and recently switched to Redline 75/90 NS. Not enough difference to justify the price and I think it was a little smoother shifting with the Mobil. FWIW, the transaxle was rebuilt two years ago by Kevin Gross and he recommended the Mobil.
what transaxle and is it an limited slip or not?
Original transaxle with LSD, 87 turbo. Also, tried one of the swepco fluids, don't remember the number, it was blue, smelled horrible and was thick as honey. Made the transaxle feel like I was shifting through mud.
thanks.
reading the "other" forums, they make it sound like your transaxle will disintegrate without swepco oil in it.
You're right on that, sharkey. Hah! I've been running Redline MT-90 in my AOR for 4 track seasons. It was a well used trans before that and I didn't rebuild it. No issues, LSD is working great, shifts fine. I'm about to change the oil in it and will use MT-90 again.
The Audi community swears by Redline for the $$/performance. And the 924/944 uses basically the same gearbox as the 016 trans that's in all the old 4000 and 200 quattro cars. I've had several of those and always used MT-90. YMMV...
