Turbo transmission fluid
How do you fill a Turbo 944 transmission allowing for the oil cooler?
What's the recommended fluid?
Re: Turbo transmission fluid
fliermike45 wrote:How do you fill a Turbo 944 transmission allowing for the oil cooler?
I use a fluid pump. The fill plug is above the drain plug. I use Swepco since mine has LSD.
Dawgz83948- Posts : 603
Transmission oil
Which Swepco product do you use with the LSD?
I've used both Redline and Mobil 1 with good results.
eclou- Posts : 102
Swepco 201
Thanks, I have ordered a gallon (smallest package) of Swepco 201 from Paragon, they have a good price.
Paragon previously supplied my lowered front springs and shocks, great service.
