What Clutch Are You Running?
A question to those who are up and running:
What clutch / pressure plate did you end up using? (P/N's ??)
Where did you buy from?
How much did you pay? (is this ok admin?)............Yes, Admin edit
Would you recommend this set up to others?
Maybe note what engine you have?
Ted
Ted
Re: What Clutch Are You Running?
Admin wrote:What engine and are you doing any mods to it?
Personally, I am in the process of the LS1 swap. Mine will be stock to start with.
I believe so. Just got mine tonight. Just looked, yes very good info.
Still, are these not relevant questions? The manual does give specific P/N information but does not give personal opinion of form, fit, function. I suppose that it give most configurations but could be others?
I'd still like to know how folks like thier set up.
Sorry if this seems irrelevant to anyone.
Not an irrelevant question, But if your motor is stock than just use a stock type clutch. Unless you are going to build big power later. Then you might look into a center force type clutch with a dual material disk.
